Thread: Catalytic Converter Questions!!!
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 116
  1. #61 Re: Catalytic Converter Questions!!!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    go with no cat. straight pipe it
  2. #62 Re: Catalytic Converter Questions!!!
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Quote Originally Posted by asite57 View Post
    That would be illegal
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  3. #63 Re: Catalytic Converter Questions!!!
    Oct 2011
    Michigan
    not in my state and thats the right way to do it
  4. #64 Re: Catalytic Converter Questions!!!
    Its a federal emission device.
    Sooooooooo a state law can't trump a federal one.
    Regardless, the info on good cats is out there.
    Thread seems to have ignored that entirely.
  5. #65 Re: Catalytic Converter Questions!!!
    Nov 2009
    I got the ZZP setup in yesterday (tuesday) so I'll be getting it installed today (wednesday).
  6. #66 Re: Catalytic Converter Questions!!!
    Nov 2009
    Agreed, it's an EPA regulation, state laws can only make the requirements even higher (like California's CARB requirements).
  7. #67 Re: Catalytic Converter Questions!!!
    Nov 2009
    All things considered, apparently all MagnaFlow cats meet EPA & OBDII stats so atleast my new setup passes those requirements.
  8. #68 Re: Catalytic Converter Questions!!!
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    Quote Originally Posted by UCF04GPGTPCompG View Post
    NO YOOOOOOOOOOOOOOUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
    I don't believe in emissions. Therefor I remove all of it.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  9. #69 Re: Catalytic Converter Questions!!!
    lulz.
  10. #70 Re: Catalytic Converter Questions!!!
    Out West
    Emissions equipment is for long haired freaky people.
    They need not apply.
  11. #71 Re: Catalytic Converter Questions!!!
    Quote Originally Posted by Nixon View Post
    HIPPIES.
    **** em.
  12. #72 Re: Catalytic Converter Questions!!!
    Nov 2009
    Got the ZZP pipe installed and all today. Fit well, but old bolts and such were rusty, so the guy that installed it had some problems with them. All in all, it worked out. The stock O2 Sensor was shot, rusted and threads died when having to remove it. Ordered a new O2 Sensor and will get that in tomorrow, install it on Friday. Right now it's running with a plug in it. Works great, fixed all the acceleration problems and such I was having. Once the new O2 Sensor is install, I'lll have the original error codes reset and then I'll see what happens.
    Question, would there be any advantage of replacing the upstream O2 sensor? I figured if I'm replacing the downstream sensor and getting a new cat that maybe now would be the time to replace the upstream as well.
  13. #73 Re: Catalytic Converter Questions!!!
    Nov 2009
    Also, if getting the upstream replaced, any brands better than others? Was planning on a Bosch.
  14. #74 Re: Catalytic Converter Questions!!!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Please don't go WOT if you don't have the front o2 sensor installed. You are making the car run pig rich (it fails into rich mode so you don't blow up the car). Ive been fine with bosch o2 sensors. I'd get a sensor from sparkplugs.com. A denso. I've had too luck with them in the o2 sensor side of things.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  15. #75 Re: Catalytic Converter Questions!!!
    Nov 2009
    Quote Originally Posted by buck531 View Post
    the front o2 sensor is the stock one, when the new cat was installed the downstream o2 sensor died (threads came off) so bought a new downstream o2 sensor. Just not sure if getting a new upsteam O2 sensor is worth it if the current one is working.
    Also, so far with the new cat system and downstream O2 sensor I haven't had any engine codes come up yet. Drove about 150miles so far so maybe I'll get lucky.
  16. #76 Re: Catalytic Converter Questions!!!
    Out West
    I run a bosch and it works perfectly fine.
  17. #77 Re: Catalytic Converter Questions!!!
    Nov 2009
    So i noticed something since I got this new setup. If idling, in gear, but stopped, the RPMs will drop from the normal ~800-700 to like ~400 and then return to normal. The duration is only for a couple seconds, with a like 15~10 second cycle time. Also, if the car is parked and running I can hear the exhaust make a "pop" sound every 15~10 seconds. Any idea what is causing this? Is it something to worry about and is there anything to do to fix it?
    It doesn't really seem to be an issue, I haven't had any problems accelerating, but just seems strange that it has problems idling.
  18. #78 Re: Catalytic Converter Questions!!!
    Misfire....?
    Could be those awesome spark plugs of yours
  19. #79 Re: Catalytic Converter Questions!!!
    Or it could be the pcm making the system super rich testing for a cat.
  20. #80 Re: Catalytic Converter Questions!!!
    Nov 2009
    If it's the pcm, would replacing the upstream O2 sensor help? Or would the best thing to do be to tune the car? Since it only seems to happen when Idling (parked or in gear but stopped) I'm not really worried about it.
    If it was a misfire of the Spark Plugs, wouldn't it happen all the time, not just at low RPMs?
  1. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  2. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
