Thread: Catalytic Converter Questions!!!
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 116
  1. #1 Catalytic Converter Questions!!!
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    So basically, my car needs a new Catalytic Converter. The question is, which cat to get and would i need to do any tuning if I get a cat other than a stock type replacement?
    I'm looking at getting the PFYC.com High Flow Catalytic Converter with the 3'' inlet and 2.5'' outlet. Has anyone bought one of these before and would I need to do any tuning to the car to make it work? I don't have any tuning software/hardware so I want to be sure that whatever I buy would work by just installing it.
    Any help with is appreciated. Also any advice for other possible replacements is good to. I'd prefer the cat to work the same, or better with no computer modifications needed. Thanks for the help!!
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: Catalytic Converter Questions!!!
    SE Level Member mosinnagant's Avatar
    May 2011
    edgewood
    magnaflow make's the best high flow's i think
    2007 Grand Prix GT - Green Filter Cone Intake, 180 F Thermostat, EGR Delete, Overkill Custom Tune, Muffler Delete with Thrush Glasspack res swap, Kenwood head unit
  3. #3 Re: Catalytic Converter Questions!!!
    Sep 2011
    Canada
    Quote Originally Posted by mosinnagant View Post
    He's right! And it shouldn't throw a code. If it does there's an easy fix! Get a spark plug fouler ($10 at NAPA) and put the O2 sensor in it, then screw it into the pipe. It will make the sensor a little further out of the pipe safely and thus not detect too much flow. I put a Magnaflow High-Flow cat on my Camaro and it never threw an engine code.
    Why do you want a 2.5" inlet and 3" outlet? Are you changing your exhaust to 3"?
  4. #4 Re: Catalytic Converter Questions!!!
    Nov 2009
    Changing the downpipes and such was just an option from a prefab part. Mostly now I'm looking into a directly welded MagnaFlow Catalytic Converter. My problem so far has been finding the correct one to get. There are sooo many different models. Double check, the 2004 GPs like mine are 2.25'' in/out pipes right?
  5. #5 Re: Catalytic Converter Questions!!!
    Nov 2009
    Has anyone actually gotten a MagnaFlow Cat for a GP similar to mine? It is a little difficult to look for the different types of cats available from this company and I have yet to do measurements of my current cat to get some idea for how big the new one should be.
  6. #6 Re: Catalytic Converter Questions!!!
    Likely it will throw a P0420 code if it's a high flow.
    Also..your exhaust isn't 3" so that may be a problem fitting a 3" inlet and 2.5" outlet into.
  7. #7 Re: Catalytic Converter Questions!!!
    Nov 2009
    I'm already getting the P0420 code because the cat has issues.
  8. #8 Re: Catalytic Converter Questions!!!
    If your signature is still up to date, the factory exhaust pipe is 2.25"...get that.
    You can get a Magnaflow High Flow off of EBay for way cheaper that way.
  9. #9 Re: Catalytic Converter Questions!!!
    And...still throw a code
  10. #10 Re: Catalytic Converter Questions!!!
    YEz.
  11. #11 Re: Catalytic Converter Questions!!!
    And...still throw a code. Not a question, a statement.
  12. #12 Re: Catalytic Converter Questions!!!
    I know,
    I was meerly agreeing with your brain.
  13. #13 Re: Catalytic Converter Questions!!!
    I agree ...too
  14. #14 Re: Catalytic Converter Questions!!!
    Nov 2009
    OK, so what would get rid of the code? Would the computer have to be tuned some for the new cat?
    I remembered I don't have a 3'' inlet, but I believe the PFYC.com is supposed to fit directly on to increase the downpipe size. Not sure though. I'll look into magnaflow, but finding a way around the code problem is important.
  15. #15 Re: Catalytic Converter Questions!!!
    Tuning could take care of it.
  16. #16 Re: Catalytic Converter Questions!!!
    Just get a catted 3" bolt-in downpipe and have someone tune it locally...I'm sure there is a Florida Grand Prix following...
    Southeast At Your grandprixforums.net
  17. #17 Re: Catalytic Converter Questions!!!
    Nov 2009
    I'm attempting to limit my car downtime and not have to spend a bunch of money. That's why I'm trying to get a replacement that wouldn't need tuning yet may still give some benefits.
  18. #18 Re: Catalytic Converter Questions!!!
    Just get a 3" catted bolt in downpipe then?
    And have a local tune it.
    There would be no down time.
  19. #19 Re: Catalytic Converter Questions!!!
    Or replace with a stock equivalent that's going to meet the pcm requirements and be done.
  20. #20 Re: Catalytic Converter Questions!!!
    Nov 2009
    Yeah, right now the estimate from my repair shop is $441.29 for the cat. Which seems very high if it's just a replacement part. The high flow cat from PFYC.com was $471.05 so if I did that, increase the downpipe size and have the repair shop just do a tune to make the engine work correctly, it may cost around the same as the original cost with a higher performance part.
    I guess I just have to see if the downpipe change and such would work correctly.
  1. catalytic converter
    By mmerrittjr in forum Introductions/Noob Questions
    Last Post: 02-16-2011, 11:49 PM
  2. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
  3. Catalytic Converter
    By LonelyLoser45 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:24 PM
  4. I need to no were i can get a catalytic converter.
    By krazyog1 in forum General Tech Discussion
    Last Post: 03-03-2009, 02:00 PM
  5. Catalytic converter?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 07:56 PM
