Thread: Boost!?
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 Boost!?
    SE Level Member Moriarity81's Avatar
    Aug 2011
    Michigan
    Alright i think i posted a thread b4 about this but i just bought my gtp its a 98 and my pillar guages the boost was only reading 0 when i floored it and the vac was like 20 at an idle? Well come to find out it was hooked up wrong so i went to auto zone and installed a new t for the boost guage and everything now at an idle the vac. Is about 10psi and holding the throttle wide open going down the road the most i can get is about 3or 4 psi of boost? I was told it should be reading about 7 or 8psi? How do i fix this? Also the stock boost guage go's about half way maybe a notch past half but no more so i think somethings up.
  2. #2 Re: Boost!?
    Texas
    Check you lines to the BBV sounds almost like the sensor came unplugged. Where did you t for your boost gauge?
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Boost!?
    Aug 2011
    Michigan
    I have no idea what a bbv is or where it woukd be lol i was told where to hook it up and thats infront of the motor there is a T on the fron of the suppercharger to the left that has a line running from under the s/c cone and the t is pluged into a little nipple thing then another line runs from the t maybe 8" to the right then plugs into another nipple thing i hooked the new t between the old t and the last nipple thing.
  4. #4 Re: Boost!?
    That's why...it needs to be "T"d in after the LIM and before the MAP sensor on the back of the supercharger.
  5. #5 Re: Boost!?
    Aug 2011
    Michigan
    what exactly does the lim and map sessor look like? i hooked it up behind the supercharger and still only get 3 psi lol
  6. #6 Re: Boost!?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    conect it to the vacuum line that goes under the supercharger snout (the end with the pulley and belt).
  7. #7 Re: Boost!?
    Wichita
    Google a vacuum line diagram.
  8. #8 Re: Boost!?
    Aug 2011
    Michigan
    thats where its connected yet im still only getting 3psi of boost max and about 18-20psi of vac. when im at an idle
  9. #9 Re: Boost!?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Sounds like the BBV valve isnt closing the whole way
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: Boost!?
    Aug 2011
    Michigan
    what exactly is a bbv valve? whats it do and wheres it located so i can check it out
  11. #11 Re: Boost!?
    Houston
    This is the bbv
    And this is the shaft the opens and closes it. Use your hand and see if you can move it up and down.
  12. #12 Re: Boost!?
    Aug 2011
    Michigan
    yes i can move that but at idle its all the way up and when i hit the throttle it opens and goes all the way down.
  13. #13 Re: Boost!?
    was the car modified when you bought it?
  14. #14 Re: Boost!?
    Aug 2011
    Michigan
    nothing major its got a aftermarket intake and i believe its programed bc its alowed to rev to 5g's in park and neutral but other than that nothing else i know of
  15. #15 Re: Boost!?
    1998's dont have a rev limiter.
  16. #16 Re: Boost!?
    Aug 2011
    Michigan
    well that dosent help me either way bc even while going down the road i cant push any more than 3 psi and the stock boost guage on the dash only goes about half way. what i was told is it should read around 7-8 lbs of boost when its to the floor
  17. #17 Re: Boost!?
    Yes they do
    To the op: you most likely have a vacuum leak somewhere, spray some carb cleaner or starting fluid around the motor until you hear a difference in the idle and where you sprayed it is your vacuum leak.
  18. #18 Re: Boost!?
    how do the vacuum fittings look? Vacuum level suggests no vacuum leaks, but its still very possible.
    Pull off the rubber connectors and see if they fall apart.
    If you have access to another car or a ride to the parts store that is.
  19. #19 Re: Boost!?
    Yes they do
    mine dont, i could floor it till it blew up, in park.
  20. #20 Re: Boost!?
    to 6000 rpm?
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
