Thread: Cranks for a long time before starting, pump or regulator?
Results 1 to 7 of 7
  1. #1 Cranks for a long time before starting, pump or regulator?
    SE Level Member MTchevy1's Avatar
    Illinois
    My 98 GTP will crank for at least 10 seconds before starting. If I turn the key to prime the pump a few times, it takes less cranking to start. How can I determine if it's the regulator not holding pressure or the pump getting weak? It runs fine and has never died or failed to start.
    Also, is there a stock replacement pump that does not include the whole module with it? I'd really prefer not to replace the whole sender assembly when it's not bad.
  2. #2 Re: Cranks for a long time before starting, pump or regulator?
    pull the vac line off the furl pressure regulator, if fuel comes out when you do that, its bad.
  3. #3 Re: Cranks for a long time before starting, pump or regulator?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I assume you mean Key on Engine Off for this fpr test, pulling vacuum line?
    1997 Red GTP 182000 miles stock
  4. #4 Re: Cranks for a long time before starting, pump or regulator?
    Key position doesn't matter. If there's fuel in the line, the reguator is bad.
  5. #5 Re: Cranks for a long time before starting, pump or regulator?
    Illinois
    Will give it a try. Any idea if I can get a stock replacement pump only?
  6. #6 Re: Cranks for a long time before starting, pump or regulator?
    St. Louis
    Maybe on Rock Auto you can.
    Also, when was the last time the fuel filter was changed?
  7. #7 Re: Cranks for a long time before starting, pump or regulator?
    TREPerformance.com $80 pumps..
  1. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  2. Cranks a little too long but stil starts?
    By ajc549FF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 01:50 AM
  3. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  4. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
