Thread: gen III to gen V fuel delivery?
Results 1 to 13 of 13
  1. #1 gen III to gen V fuel delivery?
    Willoughby, Ohio
    ive searched but cant seem to find alot of what i am looking for so thanks in advance for helping me out.
    i have a 2000 GTP and im doing the gen V swap over the winter. what are my options as far as the fuel system? since its a return style do i need to buy the $400 fuel logs or is there a more inexpensive alternative? OR would it be worth it to convert to a returnless system? i havent started the swap yet so im open for suggestions
  2. #2 Re: gen III to gen V fuel delivery?
    Out West
    Stock rails'll work
  3. #3 Re: gen III to gen V fuel delivery?
    Charles City, IA
    keep your rails.
    SMGPFC Two Nipple General
  4. #4 Re: gen III to gen V fuel delivery?
    Willoughby, Ohio
    thought i read that they wouldnt fit over the blower....but that would be the easiest route....
  5. #5 Re: gen III to gen V fuel delivery?
    Portland Oregon
    They fit just fine. Seen it done on several swaps.
  6. #6 Re: gen III to gen V fuel delivery?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    im doing the same thing and have the exact same question cuz im gettin prj fuel rails becuase im awsome and the money to waste so i have the exact same question
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  7. #7 Re: gen III to gen V fuel delivery?
    A Gen V is essentially the same height and girth as a Gen 3. The main body is longer, which results in a shorter nose drive to keep the pulley in the proper place. It also sticks out further over the exhaust than the Gen 3. But it's all good.
    Gen V, stock rails....and the 97 alternator (only my Bonne, same alt though)
    You don't need PRJ's or another solution until you raise it up for an IC.
  8. #8 Re: gen III to gen V fuel delivery?
    Willoughby, Ohio
    sweee, im not as awesome so u saved me moneys, thanks guys
  9. #9 Re: gen III to gen V fuel delivery?
    i just want to clean up the engine bay and show off the blower more
    SMGPFC #77
  10. #10 Re: gen III to gen V fuel delivery?
    Willoughby, Ohio
    ^^^i want to do that too but not at 400 whatever dollars ha ill paint the rails
  11. #11 Re: gen III to gen V fuel delivery?
    GTP Level Member AjL227's Avatar
    IL
    If anything, you want to keep your return style w/ mechanical pressure regulator. Fuel pressure increases in PSI according to manifold pressure increase.
    Fuel pressure would remain constant on a returnless...ideal for emissions, not ideal for performance.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  12. #12 Re: gen III to gen V fuel delivery?
    Not that the PCM is setup for a manifold referenced FPR.
  13. #13 Re: gen III to gen V fuel delivery?
    giggity
  1. Please help I keep having trouble with my 3.1L's fuel delivery
    By MuscleCarLvrV8 in forum General Tech Discussion
    Last Post: 09-11-2010, 10:30 AM
  2. Tipping the wing delivery guy
    By David99GTP in forum The Rant Forum
    Last Post: 02-25-2008, 09:24 AM
