Thread: Gatorback Belt size for stock S/C?
Results 1 to 8 of 8
  1. #1 Gatorback Belt size for stock S/C?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    4060660 is the belt RockAuto said I needed, so I ordered one. It does NOT fit. Is the correct size for a stock setup the 667? I came across this in a post, but wanted to be sure before I order another.
  2. #2 Re: Gatorback Belt size for stock S/C?
    667 sounds right...
  3. #3 Re: Gatorback Belt size for stock S/C?
    Portland Oregon
    667 or 670 will work. I'd err on the tighter side though
  4. #4 Re: Gatorback Belt size for stock S/C?
    Apr 2009
    It seems strange that all the belts listed were roughly the same length, by description. Apparently, they're all wrong. I usually get my belts at the dealer, but decided I'd try one of these Gatorback belts since the accessory belt is one.
    Looks like the 667 is named on the Intense site.
  5. #5 Re: Gatorback Belt size for stock S/C?
    Portland Oregon
    FWIW I did actually get a 660 belt to work on a stock pulley. It's really tight and maxes out the tensioner but I was in a pinch and it worked just fine.
  6. #6 Re: Gatorback Belt size for stock S/C?
    The Boss Iceman6669's Avatar
    Jun 2011
    660 is also what i am running on a stock pulley.. But it is a MAJOR PITA to get off and put on.
    2011 F-150 Yote powered
  7. #7 Re: Gatorback Belt size for stock S/C?
    Apr 2009
    This thing is just so tight that the only way I think it would go on is to "roll" it on and I didn't want to do that. Numbers are all worn off the old one, so I can't see what it is. I contacted the place I got the belt and asked if they would do an exchange. If not, then I'm sure I can move it on this site or on a popular auction site.
  8. #8 Re: Gatorback Belt size for stock S/C?
    Jun 2011
    yea I had to "roll" mine one too.
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. 3.4 Belt Size
    By L KELLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2011, 09:34 AM
  3. Accessory belt size
    By hunttom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 09:56 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  5. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
