Thread: Going to Replace Uim and Lim gaskets...what exactly do i need?
Results 1 to 20 of 27
Threaded View
  1. #9 Re: Going to Replace Uim and Lim gaskets...what exactly do i need?
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    I am finishing up the LIM gaskets on my 97 and saw this post. I am sorry to ask maybe a dumb question but here goes- All the car has ever had in it has been mobil 1 synthetic and I am wondering if I should use that for even the "rinse" and short drive to wash out the motor or if I can use a less $ oil to do that since it will be in the motor for less than an hour or two. If I should stay with the mobil 1 I will but it seems silly if it's a throw a way. Any input is appreciated, thanks!
    Also do I need two oil filters or just change the filter at the end of the process?
    either get the felpro brand or the alluminum ones.
    Lim gasket
    Supercharger gasket (should come with 2 yellow o rings)
    valve cover gaskets and grommets
    tb gasket (unless yours is already the rubber re-useable one.
    RTV sealant
    coolant
    brake clean/razor
    10 quarts oil (buy cheap stuff,= for 5 of them, then the other 5 for whatever oil you want)
    oil filter
    After you have the LIM off and cleaned up, and befor you go to put it back on dump 1-2 quarts of oil down the valley to wash away any coolant/debris. Then drain the oil, and fill with 5 quarts oil and go drive it for 20-40 miles and then change it again. You must do this step to prevent any coolant from being in the oil and doing damage to the motor.
    If I missed something, I'm sure somebody will chime in.
  1. VC gaskets
    By dwelles in forum General Tech Discussion
    Last Post: 08-08-2011, 04:10 PM
  2. LIM Gaskets
    By RICE KILLER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 01:24 AM
  3. LIM Gaskets
    By jmac in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 02:12 PM
  4. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  5. Gaskets
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 11:17 AM
