Thread: PCV O-ring
Results 1 to 5 of 5
  1. #1 PCV O-ring
    Jul 2011
    United States
    Does anyone have a picture of the PCV with the o-rings on it? Mine are apparently missing and I need to see where they go. Thanks!
  2. #2 Re: PCV O-ring
    Omaha, NE
    Mentioning the year of your car may help someone recognize model year changes...
    ...But as far as I know there is no O-ring for the PCV. Just a gasket on the top.
  3. #3 Re: PCV O-ring
    Jul 2011
    United States
    It's a 2000 Grand Prix GTP.
    Thanks
  4. #4 Re: PCV O-ring
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    The rubber O ring goes over the PCV valve from the bottom and seats on the little lip, then the spring sits on top of the valve.
  5. #5 Re: PCV O-ring
    St. Louis
    3 and 4 are what you will find. This is the N/A diagram, but you get the idea.
  1. Replacing Injector O-ring's [*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 04-25-2013, 12:48 PM
  2. Piston Ring Orientation
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2011, 06:49 PM
  3. CV axle: snap ring and abs ring
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 09-13-2010, 03:47 PM
  4. PCV Valve O-Ring?
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:25 AM
  5. Where do I get this? Ring Gapper
    By TubbedGTP in forum General Tech Discussion
    Last Post: 08-22-2008, 04:05 AM
