Thread: hard start and hesitation above 5k
Results 1 to 2 of 2
  1. #1 hard start and hesitation above 5k
    PA
    My 98GTP has been starting hard and hesitating above 5k. First off the hard happens if I havent drove it for a few hours it'll turn over for say 15seconds and finally grab, but if I spin it for 3 sec stop and try again if fires right off. It seems like pausing for a moment is what helps.
    The hesitation happens above 5k under WOT. It feels like it's missing but I have yet to see a code appear. Will these cars miss without throwing a code?? I also checked one of the coil packs and found the sencondary to be fine but the primary was measuring .4 ohm. My manual says it should be .5-.9 ohm could this cause an issue at high rpm??
  2. #2 Re: hard start and hesitation above 5k
    St. Louis
    Sounds like you have a fuel restriction. Have you changed the fuel filter? The hard start and waiting between cranks is allowing the system to re-prime when you turn the key again, thus building the correct pressure to fire up. The missing at 5K could also be fuel related and the car is pulling timing to keep from going too lean and blowing out a cylinder or 2.
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. Hard to start
    By vertebrate in forum General Tech Discussion
    Last Post: 08-26-2011, 01:51 PM
  3. hard start
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 12:43 AM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
