My 98GTP has been starting hard and hesitating above 5k. First off the hard happens if I havent drove it for a few hours it'll turn over for say 15seconds and finally grab, but if I spin it for 3 sec stop and try again if fires right off. It seems like pausing for a moment is what helps.
The hesitation happens above 5k under WOT. It feels like it's missing but I have yet to see a code appear. Will these cars miss without throwing a code?? I also checked one of the coil packs and found the sencondary to be fine but the primary was measuring .4 ohm. My manual says it should be .5-.9 ohm could this cause an issue at high rpm??
