Thread: throttle position voltage
Results 1 to 3 of 3
  1. #1 throttle position voltage
    PA
    I've been having trouble with my 98 gtp accelerating much over 5K, so I was looking at my throttle position sensor and I found it ranged from .4volts to 4.1volts.. my manual says it should range to 4.8 volts.
    What are the general voltage ranges for the TPS
    Thanks
  2. #2 Re: throttle position voltage
    Not sure but you can yank some out of a junkyard to see if yours shot craps. Should be pretty cheap....or a pocket part LOL
    Any check engine lights? I've never had a TPS issue on either of my cars...
  3. #3 Re: throttle position voltage
    that shouldnt be causeing your problem .7 of a volt isnt that much. it could be bulid up and dirt in it..have you tried cleaning the tb and then checking the reading
    SMGPFC Member #10
  1. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  2. Throttle Position Sensor Optimization
    By silverstreak in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2010, 03:06 PM
  3. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  4. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
