Thread: 02 GTP boost issues
Results 1 to 9 of 9
  1. #1 02 GTP boost issues
    Aug 2011
    Taylor
    Okay so, I just bought a 2002 gtp 40th anniversary I love it, but when I got the car I notice the boost guage only gets to half, and it wont stick, it'll drop and raise while it's WOT.. I unplugged the vacuum line from the solenoid and I get about 90% boost, it'll reach 100%, but drop and raise between 92-100%.. The T connector on the vacuum line below the S/C is cracked and had to be taped, so that could have boost leaks, Hopefully somebody here has a explanation, and also where can I buy the vacuum line w/ the T connectors?
  2. #2 Re: 02 GTP boost issues
    Houston
    I think you found your own explanation. I got my vac lines here Silicone Hose Kits - 7 colors
    You can stick with black or choose a different color to dress it up
  3. #3 Re: 02 GTP boost issues
    Aug 2011
    Taylor
    I'm debating on either replacing the vacuum line w/ the T connectors, or replacing the solenoid.
  4. #4 Re: 02 GTP boost issues
    Houston
    Quote Originally Posted by 02GTPanniversary View Post
    I would replace the vac lines and T first.
  5. #5 Re: 02 GTP boost issues
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Agreed.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: 02 GTP boost issues
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Unplug the electrical connector to the solenoid to see if your boost goes up.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #7 Re: 02 GTP boost issues
    Aug 2011
    Taylor
    The connector and the vacuum line both? Or plug the vacuum line back in, and just unplug the connector?
  8. #8 Re: 02 GTP boost issues
    Aug 2011
    Taylor
    With the vacuum line connected and the eletrical unplugged, only get half boost, with the vacuum line unplugged i get bout full boost
  9. #9 Re: 02 GTP boost issues
    Omaha, NE
    The only way to truely check boost is to use an actual boost gauge. Don't rely on that little bar on your dic.
  1. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Boost Issues
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 11:29 AM
