Thread: Car still heating up
Results 1 to 6 of 6
  1. #1 Car still heating up
    Jul 2011
    Lancaster, PA
    A month ago I replaced the lower intake gaskets due to coolant leak. Buttoned everything back up and runs great. No more losing coolant. Put in a 180* stat, flushed the radiator, and drained all the old coolant I could (radiator, front knock sensor, could not get to the rear knock sensor)
    Most of the time the cars temp is on the first big line. But it seems that after I get off the highway, the temps climb. Town driving, I am at the second big line.
    Any ideas why still running hot?
    Thanks
  2. #2 Re: Car still heating up
    Air in the system? Did you bleed it?
  3. #3 Re: Car still heating up
    Kansas
    How about actual temperatures... not by lines?
  4. #4 Re: Car still heating up
    HUDSON
    For a 2000 GP the second line is 210f, which for sitting in traffic without the a/c on is not hhot, but within factory spec.
  5. #5 Re: Car still heating up
    Jul 2011
    Lancaster, PA
    System was bled, and I just rechecked again, no air. My no contact thermometer reads just under 200* on both upper and lower hoses with out the fans on. Fans came on with a reading of about 210*.
    I guess it is OK, I just have more needle movement now than I did before.
    Thanks
  6. #6 Re: Car still heating up
    St. Louis
    Yep, you're right where you belong temp-wise. These motors just run hot.
  1. heating
    By aaddonis in forum General Tech Discussion
    Last Post: 12-27-2010, 06:57 PM
  2. Over heating Help
    By hefner516 in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
  3. GTP over heating
    By Brandon Busenitz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 11:06 PM
  4. Over heating?
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2008, 09:25 PM
