Thread: Taz's Offical Summer/Fall build list.
Page 10 of 17 FirstFirst ... 89101112 ... LastLast
Results 181 to 200 of 322
  1. #181 Re: Taz's Offical Summer/Fall build list.
    Still doesnt mean its right though.
  2. #182 Re: Taz's Offical Summer/Fall build list.
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    he put a base tune and changed the tables for the injectors
  3. #183 Re: Taz's Offical Summer/Fall build list.
    Odd.
  4. #184 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    Odd.
    I think its from running it with a vac leak...
  5. #185 Re: Taz's Offical Summer/Fall build list.
    vac leak = lean.
    not rich.
    Did they all look the same?
    If so, I'd venture to guess its in the tune.
  6. #186 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    vac leak = lean.
    not rich.
    yea they did all look the same...
  7. #187 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    I got my scan gauge I'm still trying to figure out all the stuff on it but heres a clip of the vac Idk If thats where I should be or not... on the fuel thing it just says 35
    VIDEO0036.mp4 video by tmo333 - Photobucket
  8. #188 Re: Taz's Offical Summer/Fall build list.
    you might not have a vacuum leak having a cam you won't have as much vacuum at idle.
  9. #189 Re: Taz's Offical Summer/Fall build list.
    set it to LTFT bank 1 and STFT bank 1
    Or O2 bank 1
  10. #190 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    how do I do that I bought it used lol
  11. #191 Re: Taz's Offical Summer/Fall build list.
    Hold both buttons to get into menu.
    Then some parameter option.
    then you select what you want to be able to view.
    then it reboots, resets your annunciator, and you can now select your selected parameters from the scan feature.
    This should help as well: http://www.aeroforcetech.com/files/I...AL_rev_2_8.pdf
  12. #192 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    cool thanks and your pretty much right this is what paul had to say
    The richness is due to it not being tuned properly yet. It was a real rough tune to get it running. After fixing the vacuum leaks, it is likely way to the negatives (probably pegged) on the fuel trims so it can't pull any more fuel out.
    oh and I keep getting a 101 codw which is MAF or VAF A ckt range/ perf I don't know what that means I'm sure google will tell me but if any of you have experience with that code
  13. #193 Re: Taz's Offical Summer/Fall build list.
    DTC P0101 Mass Air Flow (MAF) Sensor Performance
  14. #194 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    so is it a bad sensor?
  15. #195 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    Guess I could put the one from my old tb in there
  16. #196 Re: Taz's Offical Summer/Fall build list.
    Taz..I found an engine bay that's super clean. I'll have to get ya a pic. That way when you finish up with wiring etc..we can see how yours compares.
  17. #197 Re: Taz's Offical Summer/Fall build list.
    http://www.grandprixforums.net/ultim...ide-52020.html
    http://www.grandprixforums.net/mass-...car-52226.html
    I'd suggest using the Aerforce to see what the MAF frequency is at idle.
    I was under the impression the PCM compares the MAF input to the VE table to decide if the MAF is working or not.
    http://www.grandprixforums.net/ses-c...age-27572.html
    The following are general possible causes:
    Large Vacuum Leaks, split Intake Air Boot or PCV Hose, defective intake manifold gaskets
    Mass Air Flow Sensor (MAF) Circuit and or wiring problems
    Defective Barometric Pressure Sensor (possibly bad MAP input for GPs)
    Dirty or Contaminated Mass Air Flow Sensing Wire or Filament
    PCM software needs to be updated
  18. #198 Re: Taz's Offical Summer/Fall build list.
    Quote Originally Posted by Taz Magister View Post
    L67 and L36 have diff maf
  19. #199 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    really cause they look exactly the same
  20. #200 Re: Taz's Offical Summer/Fall build list.
    I'm pretty sure they are different
  1. Offical DRL (Day Time Running Lights) Thread
    By Thunderturd in forum Visual/Body Modifications
    Last Post: 04-26-2014, 11:24 AM
  2. need someone to double check the build list
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2011, 09:13 AM
  3. Help me build my Xmas list of parts lol
    By jteske88 in forum The Rant Forum
    Last Post: 07-16-2011, 10:49 AM
  4. First Offical MAGMA Meet and Greet
    By Biohazed in forum Shows and Events
    Last Post: 04-12-2011, 11:09 PM
  5. Does anyone actually fall for this?
    By ROTTMAN in forum The Rant Forum
    Last Post: 04-09-2009, 01:24 AM
