Thread: knock & P0172
Results 21 to 40 of 51
  1. #21 Re: knock & P0172
    Wichita
    Im sorry. I'm not too great at this.
  2. #22 Re: knock & P0172
    Wichita
    Im sorry. Im not to great at this.
  3. #23 Re: knock & P0172
    None of us start out good at diagnosing. Keep having issues and you'll get really good with it.
    Uh.. Not sure. With the car/key off. Pull it and check it. Make sure the place where it goes is clean.
  4. #24 Re: knock & P0172
    Wichita
    Ok I pulled the IAC valve off. Its grimy around the Oring. Ill clean it and the tb surface when it goes and see if anything changes.
  5. #25 Re: knock & P0172
    Wichita
    Ok I put it back in and I'm getting a value of 185 now. Much btr.
  6. #26 Re: knock & P0172
    Wichita
    Iac values r jumping. It went to 420 then back to 185 then up the 926.
  7. #27 Re: knock & P0172
    Still feels high.. hmmm
  8. #28 Re: knock & P0172
    Wichita
    Possibly another vacuum leake? Maybe somewhere near or before the the IAC sensor? I'll pull the MAF and TPS off and see if they are grimy like the IAC valve was. Or the sensor is failing?
  9. #29 Re: knock & P0172
    Hold up there... let me explain how some of this stuff works before you do unnecessary work.
    Vacuum leaks would cause the IAC to close. Because the IAC is nothing more than a computer controlled vacuum leak to control idle speed.
    You are haviing a fuel dumping issue and we haven't really touched on that yet. I don't think the IAC is responsible for dumping fuel. You need to pull the plugs and tell us which cylinders are carboned if any look different than the rest.
  10. #30 Re: knock & P0172
    Wichita
    Ok now I'm really stumpted. I turned the car on and the IAC values went up to 3842...
  11. #31 Re: knock & P0172
    Wichita
    Oh. So I pull one plug at a time and what do I look for?
  12. #32 Re: knock & P0172
    Wichita
    Am I looking for carbon buildup on the plugs?
  13. #33 Re: knock & P0172
    Or them being soaked
  14. #34 Re: knock & P0172
    Wichita
    Ok I checked the all. Only one was in prerfect condition, #2. The rest all had a black dot or burn on the insulator. Most appeared to have white stuff on the tip of the plug. So they are fouled? Or mechanicle damage? I looked up plugs on gnttype.org. It shows every kind of plug good or bad im thinking mine are lightly fouled.
  15. #35 Re: knock & P0172
    Wichita
    Almost forgot. Plug #1 has a few spots on the tip couldve been gas?
  16. #36 Re: knock & P0172
    Wichita
    So my spark plugs didnt look bad. No oil, barely any carbon deposit at all. Could I be running one heat range to high? Surely that cant be causing my high IAC numbers. Gnttype.org does mention lower intake manifold leaks.
  17. #37 Re: knock & P0172
    Wichita
    Some ppl on the ford forums said it could also be egr? I happen to not have one.
  18. #38 Re: knock & P0172
    Jul 2011
    Edmonton, AB
    Check your fuel pressure
    Wizaired CAI, ZZP Headers & DP, SLP cat-back, 1.8 RRs
  19. #39 Re: knock & P0172
    Wichita
    Fp is about 40-45 at idle
  20. #40 Re: knock & P0172
    Jul 2011
    Edmonton, AB
    Do your have stock plug wires? If so, swap them in..those zzp 10.3 are crap and cause misfires
  1. 04 GTP Surging and P0172
    By benblank in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2011, 03:26 PM
  2. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  3. p0172
    By 02gtp40 in forum The Rant Forum
    Last Post: 05-29-2010, 01:46 PM
  4. P0172 and P0420 Codes
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 10:21 PM
  5. p0172
    By awsom83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:00 AM
