Hi again. I encountered a more serious problem when I installed my intake manifold bolts. I could get one of the bolts to go in and from the picture below the first two threads on the screw are bent. Since it only affects the first two threads can I use a tap to try to fix the threads in the hole or should I just drill out the first two threads in the hole. I have never done anything like this before. Any advice would be much appreciated. I don't want to make it worse so if it's doable I'm game. Otherwise, I can see if the dealership would do it. Can I drive my care without one intake manibolt whole open?
Thanks
