Thread: Car is running hot !!!
Results 1 to 15 of 15
  1. #1 Car is running hot !!!
    SE Level Member Dobbs122's Avatar
    Shelby Ohio
    I made a simple intake a couple days ago noticed the Intake Air Temperature Sensor was banged up. and today the car was running at 200 degree's ! i did go and fill up the coolent that did nothing.
    Last edited by Dobbs122; 08-12-2011 at 10:40 AM. Reason: red tape was the last owners idea of extending the sensor
  2. #2 Re: Car is running hot !!!
    You have a check engine light?
    Because that's the IAT sensor...it has nothing to do with controlling engine temps...that just tells the PCM what the incoming air temps are. It has been pretty hot recently...sure that isn't it...plus if you still have a stock tune...with stock fan turn on points...and a stock T-Stat...200* isn't hot...when your getting past 228*...then I'd worry.
  3. #3 Re: Car is running hot !!!
    since when is 200 hot????????????????????????????????????
    our cars love to run at around 195-205
  4. #4 Re: Car is running hot !!!
    Shelby Ohio
    seems hot to me i dont know why lol. but it just felt like the car was running hot and crappy i just freak out about engine temp what can i do too make it run cooler?
  5. #5 Re: Car is running hot !!!
    Shelby Ohio
    yes MAF code but it went away today and came back so i figured it was just the same code
  6. #6 Re: Car is running hot !!!
    Never Never Land
    Mine's gotten up to 230* a coupe times.
  7. #7 Re: Car is running hot !!!
    Shelby Ohio
    I had a piece of crap of sunfire that would over heat all the time thats why i was like wtf not my gp lol this is the first time i noticed it get that hot
  8. #8 Re: Car is running hot !!!
    Quote Originally Posted by Dobbs122 View Post
    MAF and the IAT are two totally different things tho...
    If your still running a stock 195* T-Stat...then that's not hot...because there is still about a 10-20* leway in what the temp of the tstat is to what the ACTUAL temp is...where I see on my Aeroforce...I see anywhere from 168-182...and I run a 160* T-Stat...so where I assume a 180* would get close to 200 and a 195 might be around 220* tops.
    If you want to keep the car cooler...get a tuned PCM and a 180*...and get some headers...those cast iron manifolds like to hold in heat...along with the engine cover and hood liner...toss that crap out too.
  9. #9 Re: Car is running hot !!!
    Shelby Ohio
    Im getting headers next month speed daddy's. got the hood liner and cover off still have stock heads could i get the pcm now before the headers ? i want to add perf shift cant with my stock i tryed and it did not work
  10. #10 Re: Car is running hot !!!
    You run a wire to the pin #23...or #26....can't remember...then run it to the Perf. Shift knob...that's it.
    Stock heads...have to do what with a PCM and headers? Are you tearing the motor down to get the heads ported? If so...that would help kill knock and allow for more of a pulley drop...but won't let the motor run COOLER really.
  11. #11 Re: Car is running hot !!!
    Shelby Ohio
    no porting just headers and a 3.4 when i have all the supporting mods. but when i tryed the add perf shift i used a cheap toggle with a positive ground and negative and had no luck with it all hooked up thinking it was the switch
  12. #12 Re: Car is running hot !!!
    Get the actual shift knob...breh
  13. #13 Re: Car is running hot !!!
    Shelby Ohio
    cant find one posted in the wanted section with no bites lol
  14. #14 Re: Car is running hot !!!
    Check your local junkyard's or check out Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    OR
    You can spend tons of money on the entire kit...from PFYC.com Last I checked a long time ago it was like 150 bones
  15. #15 Re: Car is running hot !!!
    Destroys cars izup69's Avatar
    Iowa
    If you want your car to run cooler without doing anything to it. Add a bottle of purple ice. Its a radiator additive you can drop temps of up to 28* its pretty good. Had a old lt1 ta that ran hot droped a bottle of it in. It usually ran about 220-225 after I put that in ran about 205-210. Worth it for a few bucks
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  1. Car running hot
    By ShinyWhite99GTP in forum General Tech Discussion
    Last Post: 12-26-2010, 10:00 PM
  2. running hot
    By PatriotGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2010, 08:04 PM
  3. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. running hot ??
    By rickchall69 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2009, 02:55 PM
