@@#%$@!........%#$@!##$$%!#!@#.....Well im pissed. O2 sensor didnt fix my problem. Seems like it is a misfire problem. At least i hope it is because i have nothing more to go on. Un- deleated all the misfire codes and I got a ''P0300-misfire detected''(could be from the cam could be from the misfire problem im having) and im also getting a ''P1380-misfire detected-rough road data not available''. Any body know of anything to check with the p1380 code? Going to try to swap out the coil packs tomorrow with a friends. Well see if that works.
The misfire only seems to happen in the higher rpm's and when im heavy into the throttle.
I can ease into the throttle and bring it up to 6000 with out much of a problem. It will still give me a cupple blips though.
I can pretty much drive with heavy throttle up untill around 3500 rpm's....then it starts bucking and misfiring.
Any ideas? I mean the only thing that i see that can do it would be the coil packs. But then again i thought it was the o2 sensor. The o2 sensor does seem to be acting more normal now with how it is suppose to be fluctuating and all. And no o2 codes....YET.
So maybe i fixed one problem...If not I just wasted another 50 bucks on a denso o2 sensor. And yes I made sure I soldered all the wires correctly and heat shrunk them ect.
