Excellent info - thanks.
I started @ 0.055" with my new plugs.
I used to run Champion Cu cores gapped @ 0.060". I would get misfires or knock @ higher RPM (with this "setup"). I blamed Champion - perhaps it was the gap. The cheapo Pt Bosches (not gapped design) performed flawlessly with the same setup.
Aside from the athletic wear, I don't have a single good thing to say about them. All their products are absolute trash. Their plugs are well-known to cause major issues.
On the other hand, Bosch plugs are also known to cause performance issues. AC Delco, NGK and Autolite are the most-used by forum-goers.
i am installing a new air intake, 180 t-stat, headers, plugs and wires on mon (pully drop and pcm next month). i'm thinking al104's?...same gapping? will it need to change with pully drop? also with those mods is 3.4, 3.5, or 3.6 pully appropriate?
Mine seem to be doing fine.
Minus the slight cool burn due to the wrong temp spark plug.
mmmmmmmmmmmmmmmm
lol. camera focused on the floor. technology is great.
Free cellphones aren't expected to have functioning cameras.
Coppers tend to preform well for 10k so I would figure 6k or so for side gapped plugs.
i put maybe six thousand miles per year on it.
What did you start your gap at Matt?
.045" and left it.
