Thread: valve train noise-Mysterioussss
Results 1 to 20 of 20
  1. #1 valve train noise-Mysterioussss
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    alright here is the lowdown- 06 L32 gen V, xp cam, modified intense stage 2 heads fresh back from the machine shop. new si valves, valve job, new guides seals etc,(installed height correct) new LS7 lifters, new comp pushrods, cometic .052 head gaskets, new comp 105 springs(shimmed to exacly 105lbs), new retainers, locks.
    Checked preload just cuz of head machining, thin gaskets etc. Preload good with betw 1 and 1.25 turns. (correct length pushrods now) also measured w dial indicator. all good. Checked oiling to heads-flows good. assembled with cam/lifter prelube. went thru all bs "break in" crap.
    i have a mysterious "tap" coming from the front bank of cylinders in the vicinity of cylinder 5. Its def not a lifter tick, not a knock.
    i can only describe it as a tap.
    I had it runnin with the valve cvr off, oiling is good, nothin funny goin on. even swapped out the rockers with another set i have just to be sure its not them. Swapped the pushrods from cyl 5 to 1.
    NO change.... everything looks and assembled perfectly.
    Cant hear it at idle, only between 1500 and 2000rpms. very distinct noise then.
    I am at a loss on what it may be. Need to get the car tuned and dont want to till i know its not gonna blow up! HELP!
  2. #2 Re: valve train noise-Mysterioussss
    Jul 2011
    oregon
    Have u tried taking out the spark plugs and checking them seeing if electrodes smashed up etc one time I did a cam swap and had a dam washer in one of the cylinders quiet at idle then tap tap tap wen rpms went up jus throwing a idea out there
  3. #3 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    yeah spark plugs ok... considered taking it to a shop and having the cylinders scoped to see if anyting looks funny..
  4. #4 Re: valve train noise-Mysterioussss
    Banned
    Jun 2011
    my L67 had a tap tap tap...tore it down...twas a wrist pin
  5. #5 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    hmmmm. only 40k miles on this motor. prolly only 8k since the cam install....
  6. #6 Re: valve train noise-Mysterioussss
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Bad injector? They tap.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  7. #7 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    nope. not an injector noise..
  8. #8 Re: valve train noise-Mysterioussss
    SE Level Member Hixc's Avatar
    Lawrence MA
    im going to second that wristpin
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  9. #9 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    would you think that a "wristpin" noise would change if i pulled the spark plug for any given cylinder? Tried that, revved it to the typical rpms where it makes the noise, and no change of the tap/tick whatever noise..
  10. #10 Re: valve train noise-Mysterioussss
    Lawrence MA
    can you post a video of it? under the hood. if you havn't tried already, use a garden hose, hold it up to your ear, try to pinpoint the noise exactly. or something like that.
    does it do this in neutral? does it do it only in a certain gear? only while driving?
  11. #11 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    ill try and get a vid. its tough to do cuz its only at like 1400-2000 rpm. in park. doesnt do it while idling, most of the time. cant hear it while driving.
  12. #12 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    and i took the stethescope to each rocker bolt while the engine was idling and didnt hear anything out of the ordinary.
    To me the noise almost sounds like a valve slapping closed.. idk
  13. #13 Re: valve train noise-Mysterioussss
    Lawrence MA
    Quote Originally Posted by danomite02 View Post
    open the throttle by pulling the throttle cable on the TB to get it to rev, while holding the camera :P
  14. #14 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    ya ya ya... now if i could only get my camera to work :/
  15. #15 Re: valve train noise-Mysterioussss
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    have the same dam noise in mine in the same rpm range, same cam and headgaskets as you but in a l67, made the noise before the cam swap, put new lifters and cam bearings in at the time of the swap and still has it, also measured lifter preload and got that all good and still have the sound. mine first started making noise about 5000 miles after a complete rebuild, put about 500 miles on it since and hasnt gotten louder or come apart
  1. Noisy valve train intermittent oil pressure
    By Rico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 06:50 AM
  2. valve train tick...
    By jayn in forum General Tech Discussion
    Last Post: 03-19-2011, 07:28 PM
  3. 02 gt 3.8L valve noise, oil pressure related
    By chevymx78 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 07:11 PM
  4. Valve train questions
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 09:54 AM
  5. Valve train questions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 05:59 AM
