Thread: valve train noise-Mysterioussss
Results 1 to 20 of 20
  1. #1 Re: valve train noise-Mysterioussss
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    have the same dam noise in mine in the same rpm range, same cam and headgaskets as you but in a l67, made the noise before the cam swap, put new lifters and cam bearings in at the time of the swap and still has it, also measured lifter preload and got that all good and still have the sound. mine first started making noise about 5000 miles after a complete rebuild, put about 500 miles on it since and hasnt gotten louder or come apart
  2. #2 Re: valve train noise-Mysterioussss
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    ^^^ car looks good ^^^
    ya i have just been driving it like i usually do, not sure what else i can do.
  3. #3 Re: valve train noise-Mysterioussss
    Jan 2009
    State College PA
    Quote Originally Posted by danomite02 View Post
    thanks, i dont have mine out much, keep it out of rain most of the time and ive tried and checked everything i can think of, so im just going to run it and hitting the track with it in a month or 2
  4. #4 Re: valve train noise-Mysterioussss
    Jul 2011
    oregon
    I know this highly unlikely but did you check piston depth vs valve clearance since I saw u went to a thinner head gaskets and a cam with more lift might be the valves slightly tapping one of the pistons from bad grind on 1 of the lobes, throwing another idea out there
  5. #5 Re: valve train noise-Mysterioussss
    Jan 2009
    State College PA
    on mine it had the noise before the cam swap
  6. #6 Re: valve train noise-Mysterioussss
    Jul 2011
    CT
    hmmm. well i ran the xp with these heads for at least 6 k miles without any noises. before that the xp was in an l67 eng b4 i chipped a piston and replaced it with the current L32. i dunno.. prolly just gonnna run it and hope for the best LOL
  1. Noisy valve train intermittent oil pressure
    By Rico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 06:50 AM
  2. valve train tick...
    By jayn in forum General Tech Discussion
    Last Post: 03-19-2011, 07:28 PM
  3. 02 gt 3.8L valve noise, oil pressure related
    By chevymx78 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 07:11 PM
  4. Valve train questions
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 09:54 AM
  5. Valve train questions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 05:59 AM
