No i haven't had a chance for a compression test yet..hopefully tomorrow...it annoys.me.i can't.work on it every day..but too many irons in the fire..soto speak...
Ok..so....an update......my battery is currently charging....did compression test on four of the six cylinders...3 has no compression at all....the gauge just twitches...every other one has checked out fine...gonna go back out in a bit and finish the test....
Ok..another small update....checked two and four.....they are weaker than one and five..but are leaps and bounds better than three.....it has a pretty good oil leak from the back valve covers....don't know if that would have anything to do with it....
yup number 3 is gone, pull the heads off and learn how to take these cars apart and take pcis for us then get another engine.
Leaky valve cover would have nothin to do with no compression.. Time to look for a used engine...
I had plugs that looked like that once. My TSI leaned out hardcore and melted them.
I lucked out and "only" fried the rings.
I was reading as I was typing and meant to say I had plugs that looked like that once. LMAO.
You know what I meant though.![]()
Ok..so i might have a regular 3.8 lined up for 200-250....wont know for sure until Monday...began teardown of original motor tonight..but due o my limited experiance..was only able to get the supercharger off.....but i will be working on it more tomorrow hopefully....guess ill try a topswap.....and retune lol
Perfect time for a top swap!
