Thread: mass air flow sensor?
Results 1 to 10 of 10
  1. #1 mass air flow sensor?
    SE Level Member tcafego's Avatar
    Aug 2011
    taylor, mi
    How expensive to replace the mass airflow sensor? How bout the crank shaft position sensor?
  2. #2 Re: mass air flow sensor?
    London Ont, Canada
    Check Autozone.com
  3. #3 Re: mass air flow sensor?
    Feb 2009
    flintnasty MI
    go to a local junkyard with the right bit... it costs about as much as your pocket wants it to cost.
  4. #4 Re: mass air flow sensor?
    London Ont, Canada
    if you think your maf is bad, try cleaning it with maf cleaner first, usually does the trick
  5. #5 Re: mass air flow sensor?
    Aug 2011
    taylor, mi
  6. #6 Re: mass air flow sensor?
    thats just a vacuum line off the evap, just buy some vacuum hose and replace it.
  7. #7 Re: mass air flow sensor?
    Replace that tubing...then see if your other stuff is bad...are you sure? What codes is your car throwing if any?
  8. #8 Re: mass air flow sensor?
    Aug 2011
    taylor, mi
    Anyone happen to know the part number or just the name of that broken hose? Autozo.e and oreillys really didn't really tell me anything but it leads to the evap purge solenoid
  9. #9 Re: mass air flow sensor?
    You can buy the entire vacuum set from your local dealership. Go there and have them pull up a picture of the L67 and say I want THAT *point at the vacuum line*
  10. #10 Re: mass air flow sensor?
    Aug 2011
    taylor, mi
    Thanks will do
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. Which of the following is the MASS AIR FLOW sensor that I need on my 98 GTP?
    By vanels in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2010, 10:22 AM
  3. Mass Air Flow Sensor
    By msh227 in forum General Tech Discussion
    Last Post: 10-19-2010, 11:39 AM
  4. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
