Thread: cooling issue
Results 1 to 3 of 3
  1. #1 cooling issue
    Jun 2011
    columbus ohio
    ok i have replaced the intake gaskets (intake looked great 133,000 mies) water pump and radiator also coolant temp sensor. i have to use a 160 degree stat and had to disconnect the wire on the temp sensor that runs to the computer so that the fans will run all the time by doing this the car runs where it should in between 160 and 210, if i run a 180 stat the car will run at 210 if i use oem 195 stat it runs up in the danger zone. i work at an auto repair shop and this has mechanics with years of experience stumped what could be making the car run so hot
  2. #2 Re: cooling issue
    um use a 195 and bleed the cooling system really well.
    I run a 195 and never get above 205.
  3. #3 Re: cooling issue
    Jul 2011
    Edmonton, AB
    Are you getting your temps off the gauge cluster temp gauge? Maybe it's faulty...
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. Cooling fans and A/C issue *need help
    By WRIGHTDA in forum General Tech Discussion
    Last Post: 10-06-2012, 11:45 PM
  3. Stumped on cooling fan issue
    By indy99gpgt in forum General Tech Discussion
    Last Post: 07-01-2012, 10:57 AM
  4. Cooling Issue
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 06:51 AM
  5. weird cooling issue
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 05:44 PM
