Thread: Intake not Sucking air gtp
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Intake not Sucking air gtp
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    Lmao no def not the gas cap. i sprayed carb cleaner just about everywhere without success.. all hoses seem to be fine. could it be a gasket or somthing?
  2. #22 Re: Intake not Sucking air gtp
    Have you changed any said gaskets recently?
  3. #23 Re: Intake not Sucking air gtp
    May 2011
    canada
    Blue, no i havent wich gaskets should be replaced
  4. #24 Re: Intake not Sucking air gtp
    You said could it be leaking from a gasket...which I asked if you had changed any recently because that might be the cause of it...
  5. #25 Re: Intake not Sucking air gtp
    EGR tube?
    they can crack and dont react to carb cleaner test.
    Unbolt the bit where it goes into the LIM and check.
  6. #26 Re: Intake not Sucking air gtp
    May 2011
    canada
    anyone know what that is? was a hole in it didnt react to carb but once i covered it intake started working again
  7. #27 Re: Intake not Sucking air gtp
    Larger picture? Where is that even at? Somewhere next to the bell housing...?
  8. #28 Re: Intake not Sucking air gtp
    May 2011
    canada
    its far down in engine bay under intake/maf runs from engine all the way arround front of car to passenger side
    ill go take a better pic
  9. #29 Re: Intake not Sucking air gtp
    May 2011
    canada
  10. #30 Re: Intake not Sucking air gtp
    Quote Originally Posted by kyleinkman View Post
    i got it all figured out!
    your engines in backwards or something like that.(mirrored) that pic messed my head up for about 3 minutes lol
  11. #31 Re: Intake not Sucking air gtp
    Jan 2009
    Tallahassee, FL
    I looked at mine and it's a vac line that goes to the tranny, on the front of the bell housing, then it just disappears into the harness somewhere.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #32 Re: Intake not Sucking air gtp
    May 2011
    canada
    well with anyone with a fuel lean bank 1 thats the vacuum that sets off the code reset my error codes and did about 5 cycles code hasnt came back. side note this line doesnt react to carb cleaner
  1. Short Ram Air intake or Cold Air Intake
    By slopez in forum General Tech Discussion
    Last Post: 02-01-2011, 10:08 PM
  2. Air Intake
    By JAMIEPERRY86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 06:06 PM
  3. 3.1L Intake
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-26-2009, 02:32 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
