Lmao no def not the gas cap. i sprayed carb cleaner just about everywhere without success.. all hoses seem to be fine. could it be a gasket or somthing?
Have you changed any said gaskets recently?
You said could it be leaking from a gasket...which I asked if you had changed any recently because that might be the cause of it...
EGR tube?
they can crack and dont react to carb cleaner test.
Unbolt the bit where it goes into the LIM and check.
Larger picture? Where is that even at? Somewhere next to the bell housing...?
well with anyone with a fuel lean bank 1 thats the vacuum that sets off the codereset my error codes and did about 5 cycles code hasnt came back. side note this line doesnt react to carb cleaner
