Thread: somethings up in the front cover-Dropped valve
Results 1 to 20 of 34
  1. #1 Re: somethings up in the front cover
    Bastard Reptile's Avatar
    Kansas City, MO
    what sound did you have coming from the front cover? was it just some kind of grinding?
    It may just be what happened to me and the gear split, making a bunch of noise. If that's the case then your valves may be ok. Chances are the oil pump gear is what's holding your timing gear together.
  2. #2 Re: somethings up in the front cover
    GT Level Member Preotic's Avatar
    Missoula, MT
    We(me and 2 buddies) think the gear split and then somehow came back together but a few degrees off. I was getting into the throttle and it sounded like a backfire and my pull was instantly stopped and the car was idling like crap and a heard a tick. After pulling over the car wouldn't start but it turned over. After my friend arrived, i showed him it wouldn't start, he then asked me to put the gas to the floor. The car started but it didn't run well and there was a noise coming from the front cover(he mentioned it was fast enough to be bottom end). It acts like the timing is off. I haven't touched the car since monday the 7th because i'm pissed and upset so i'm taking my time getting to it. I'm hoping I'm just gonna have to replace the rollmaster.
    Can i measure the height of the valves with the covers off, to check for a bent valve?
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  3. #3 Re: somethings up in the front cover
    Barksdale AFB, LA
    Quote Originally Posted by Preotic View Post
    If you don't want to pull the heads, a bore scope through the spark plug holes would be the best way.
    2009 Subaru Impreza WRX STI
  1. Lets see your painted/smoothed/custom front valve cover
    By snow99dohc in forum Visual/Body Modifications
    Last Post: 06-22-2008, 11:37 PM
  2. somethings not looking right..
    By monte0 in forum PCM Tuning
    Last Post: 01-27-2008, 08:32 PM
