Thread: recall on 02 fixed now check eng light
Results 1 to 12 of 12
  1. #1 Re: recall on 02 fixed now check eng light
    Jun 2011
    Detroit, MI
    whats the SES code???
    Haha he doesn't know! Most people don't have scanner things, including myself. Can't you get it checked at autoparts stores or something?
    iLoveSpade
  2. #2 Re: recall on 02 fixed now check eng light
    PA
    Quote Originally Posted by Hippo Machine View Post
    Yes, most parts stores, which are on about every corner anymore, will check them for free. Takes all of 2 minutes.
    2001 GSE
  3. #3 Re: recall on 02 fixed now check eng light
    GT Level Member RegalGS98s's Avatar
    NJ
    I know the recall is for the valve covers, but I think it also included new spark wire retainers. One of the spark plug wires could be damaged or not securely pressed on the spark plug. Get the check engine light code checked at the autoparts store for us to lead you in a better direction.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  4. #4 Re: recall on 02 fixed now check eng light
    Jul 2011
    Illinois
    ok guys thanks just got home will get it checked on thursday and give more info thanks
  1. 2002 Grand Prix MPG improvement and Check Engine Light gone!!! fixed by chance
    By mtsav8or in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2011, 11:21 PM
  2. Fuel economy improved and check engine light gone - fixed by chance
    By mtsav8or in forum General Tech Discussion
    Last Post: 07-11-2011, 08:56 AM
  3. weird electrical issue oil light on with key off !FIXED!
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2010, 04:58 PM
  4. check light.....
    By bballa0740 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-23-2009, 02:37 PM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
