had this in another thread but i figured i would start one just for the issue
anyway 04 GP gtp comp G with 113k miles it gets pretty sad mpgs even though i drive about 80% highway at 70mph and at that speed while not beating on it the trans temps get as high as 225 * consistently i would say 90% of the time that the transmission is warmed up it is over 200*
i just cant figure out the issue, its about to get headers, new o2 sensors and a highflow cat and i hope that helps
so far i have replaced
plugs (factory replacements) and wires (bosch lifetime warranty)
changed supercharger oil
k&n cone filter
transmission filter and fluid (merc 3?)
fuel filter
took the throttle body off and cleaned it to the point of being almost spotless
cleaned the mass air flow sensor with electronic parts cleaner
tires are about 5k old with 35ish psi
if it matters the car says the alternator is charging well (between 13.8-14.5 volts)
coolant is still dexcool but still looks bright orange/red
car no engine lights on
