So i met len today, good guy! his car just stalls out at idle at weird times. we started it and let it sit, everything sounds good. it sat for about 15 mins at idle while we talked. then we took it for a spin around the block, again everything was fine. when we got back to his house we let it sit and after a couple mins the engine just shut off, no shudder or misfire, it just cut out like someone turned the key but left it in the on possibly. we started it up, started normal, let it sit for min and it did it again. theres no warning signs it just shuts off.
we did find that the small piece of vac line at the lim under the snout was cracked but i dont think its enough to cause this and the lean code. and at the time this all happened the SC did sound kinda rombley, like a bad coupler but on the TB side of it.
