Thread: Wont Start - wtf
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
  1. #41 Re: Wont Start - wtf
    Jun 2011
    Middletown, NY 10940
    This is interesting a few times i stalled in the last week.
    This happened when I would heat up tires from a stop.. I would punch them free and hold at 4K to let them burn a bit and when I let go car would stall.
    I just assumed the idle was a touch low and when i let go it was dropping but after reading ur posts I am wondering if that is a symptom of my crank position sensor going bad? it never stalled at other times or had other symptoms only a few times where i punched it and then let go of thottle.
    Daily Regal GS
    Weekends Spyder GST
  2. #42 Re: Wont Start - wtf
    Only one way to find out what's wrong. Start testing.
  3. #43 Re: Wont Start - wtf
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Get anything checked today Ed?
    For all your 3800 needs:
  4. #44 Re: Wont Start - wtf
    Jun 2011
    ok between breaking my foot and the rain I finalyl got some **** done and got the car to FIRE - it wont stay on though....
    Starter fluid started it... It is a fueling issue...
    I also got a code to pop although i dont know what it means
    p1641 Malfunction Indicator Lamp (MIL) Control Circuit
    thats my only code and of course car wont stay on.... coudl use some help it is Friday night and perhaps this is an easy fix???????
    Daily Regal GS
    Weekends Spyder GST
  5. #45 Re: Wont Start - wtf
    Jun 2011
    I took the ground on the head below the belt tensioner cleaned it and spliced a wire to reinforce the ground in case that was it and no luck...
    I put a bulb ot the injector harness and it did not flicker.. so my injectors are not getting a pulse to fire and i am assuming there in lies my problem....
    I jsut dont know how to tackle this problem
    Daily Regal GS
    Weekends Spyder GST
  6. #46 Re: Wont Start - wtf
    Orange County, NY
    Start testing the wiring from the injectors back, you should then be able to isolate where the issue is.
  7. #47 Re: Wont Start - wtf
    Texas
    Is the security light flashing and have you done a security relearn? Google the diagnostics code or go to gpona and look at the GM service manual. It should give you a step by step process for diagnosing the code.
    85 Corvette
    01 TA
    03 Z06
  8. #48 Re: Wont Start - wtf
    Jun 2011
    i read that the could be just from cranking ignition too long and htititng low voltage dont know how true that is...
    I really am lost when it comes to wires and testing them but thats waht i am gonna try jason.... do u have a good tool to do that?
    I have a multimeter is that the right tool?
    Daily Regal GS
    Weekends Spyder GST
  9. #49 Re: Wont Start - wtf
    Sep 2011
    IL
    I'm having a similiar problem with the injectors not firing. Did you ever get this figured out?
  10. #50 Re: Wont Start - wtf
    Jun 2011
    It is my beleif it is crank pos sensor
    Daily Regal GS
    Weekends Spyder GST
  1. wont start
    By 65mn in forum General Tech Discussion
    Last Post: 07-20-2011, 04:56 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 93 with 3.1 wont start!
    By rvdavis in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-02-2009, 05:27 PM
  4. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
