Thread: Overhead engine support
Results 1 to 11 of 11
  1. #1 Overhead engine support
    SE Level Member Phyrstorm's Avatar
    Jun 2010
    Sioux Falls, sD
    Had anyone ever used an overhead engine support on a grand prix? Like one of these Amazon.com: Lisle 58000 Engine Hanger: Automotive.
    Also has anyone tried to build their own?
  2. #2 Re: Overhead engine support
    St. Louis
    What exactly are you trying to hang the motor to do? I had to do this on my old motor to get to the pan and just used 2 2x4's on their edge between the fenders and a chain on the stock hooks of the motor. Never even moved.
  3. #3 Re: Overhead engine support
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    ^^^ This.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  4. #4 Re: Overhead engine support
    Jun 2010
    Sioux Falls, sD
    Frankly not sure what I'm going to end up doing with it. Going to be working on several things and can't feasilbly pull the motor out just wondering how well these work before I start building one from high grade steel tubing.
  5. #5 Re: Overhead engine support
    GT Level Member sic6's Avatar
    san marcos, tx
    Harbor Freight sells them. I purchased one for $45. They work great.
  6. #6 Re: Overhead engine support
    Jun 2010
    Sioux Falls, sD
    Yay, road trip to Sioux City. Guess I better bring a boat.
  7. #7 Re: Overhead engine support
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I just used some angle iron bolted together with some 8 gauge wire to wrap around the engine brackets.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  8. #8 Re: Overhead engine support
    Charles City, IA
    I jack our OTC one from work when I need it it works great.
    Amazon.com: OTC 1725 Three Point Engine Support Bar: Automotive
    SMGPFC Two Nipple General
  9. #9 Re: Overhead engine support
    Jun 2010
    Sioux Falls, sD
    Well looks like i'm just going to pull the whole thing anyway. Cost of a cheap foldaway hoist and engine stand is low enough to just go ahead and buy a set. Unless I can borrow a set from a friend since I am already borrowing his spare pickup.
  10. #10 Re: Overhead engine support
    I'm a 4x4 kinda guy.
  11. #11 Re: Overhead engine support
    Jun 2010
    Sioux Falls, sD
    Lucky for me it is a 4x4. 95 dodge dakota that was rebuilt after a nasty accident back in 98. Only has 120k miles. Going to try to convince him to sell it to me.
  1. Overhead lights not working.
    By GtpZach in forum General Tech Discussion
    Last Post: 07-08-2011, 01:00 AM
  2. Noise Vibration in Overhead Console - 08 GP
    By wiynib in forum General Tech Discussion
    Last Post: 01-17-2011, 11:42 AM
  3. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
  4. OverHead Display Dimming Prob.
    By SuperChargedMook in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2009, 10:32 PM
  5. Got A Dilema, Which Engine Support
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 06:03 PM
