Thread: Car wants to die while turning
Results 1 to 10 of 10
  1. #1 Car wants to die while turning
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Since I did my cam install, my car wants to die on sharp, slow left turns. It seems to only happen on a cold engine. I have to give it gas, as the RPM drops down to around 400. I know sharp turns put a greater load on the power steering pump, which affects engine performance, but this is way past normal.
  2. #2 Re: Car wants to die while turning
    Try raising the rpm by 100-150 for the in gear area.
  3. #3 Re: Car wants to die while turning
    Yea I already raised it a bit, I'll try add a bit more. Thanks Bill.
  4. #4 Re: Car wants to die while turning
    Odd, it's understandable because the car is in gear on decel usually. So it's trying to idle around 650rpm. Which can be tough depending on the cam. Then add the stress of AC and PS to the idle heading down. That's the typical issue. Bump a little takes care of that.
    however Brandon, with you.. we know you might come up with some really oddball issue that we'll have a heck of a time figuring out.
  5. #5 Re: Car wants to die while turning
    Its just strange that it only does it when cold. Maybe I'll have to tweak the AFR too, as it's a lot richer on a cold start.
    Haha, yea I tend to find ways to implode minds in this forum.
  6. #6 Re: Car wants to die while turning
    Didn't it feel wrong putting those in upside down?
  7. #7 Re: Car wants to die while turning
    Shut up!!! Haha.
  8. #8 Re: Car wants to die while turning
    I'm just sayin...wasn't it tough to do, a little awkward?
  9. #9 Re: Car wants to die while turning
    I wasn't even thinking I guess. I'm not sure how that happened
  10. #10 Re: Car wants to die while turning
    GTX Level Member cerick08GP's Avatar
    I’d check for bare wires in the engine compartment. I’d start with the spark plugs then move onto sensors. Many times after ppl have messed with there engine the plug wires lay different afterwards and get melted through.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  2. Whining while turning
    By randyb in forum General Tech Discussion
    Last Post: 01-14-2011, 10:33 AM
  3. Key not turning back all the way.
    By DJO in forum General Tech Discussion
    Last Post: 04-14-2009, 09:03 PM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
