Thread: h bar removal
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 h bar removal
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    How hard is it to remove the h bar from a ported blower? Ave been trying.to get a ic ported blower for 3 weeks and im thinking of just taking my h bar off the one i have so i can install my Damn intercooler. I have a dremel and how long would it take?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: h bar removal
    GTX Level Member Juanmiguel's Avatar
    Mexico
    should be fairly quick. I've done similar stuff with just a hacksaw to the TB in around an hour. It should be around the same with a dremel.
  3. #3 Re: h bar removal
    Bowie, MD
    Not too bad. How should i.go.about doing it? And what diesel acc. Should i use?
    Heres my current ported case by reptile.
  4. #4 Re: h bar removal
    that's a lot of material to take out with a dremel. you can do it, but its gonna take a while.
    take it to someone with a lathe and theyll do it in 5 minutes.
  5. #5 Re: h bar removal
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    Don't you mean a Mill? A Lathe will cut stuff that is round.
    The hardest part in Milling the "H" bar is the setting up the machine and holding the S/C somehow to the Mill Table. I have done it several times, it just take a little while to do it.
    It can be done with a Dremel, just get the right bit to do it.
  6. #6 Re: h bar removal
    Grand Island, Nebraska
    You can use a cutting wheel and try to cut it off instead of grind it off. Then smooth it out afterwards.
  7. #7 Re: h bar removal
    GT Level Member redgtp97's Avatar
    IL
    i ported my blower with a dremel, it took a while but it got the job done.
  8. #8 Re: h bar removal
    Nov 2009
    Grand haven
    Ohhhh snap ^^^
  9. #9 Re: h bar removal
    Forgive him, he was probably drunk when he wrote that
  10. #10 Re: h bar removal
    Bowie, MD
    Thanks for your help guys.
  11. #11 Re: h bar removal
    Pneumatic grinder would be faster than a dremel.
  12. #12 Re: h bar removal
    Bowie, MD
    So far......
  13. #13 Re: h bar removal
    Getting close
    How do you like that dust everywhere? Lol
  14. #14 Re: h bar removal
    Bowie, MD
    Quote Originally Posted by JoRoW99 View Post
    Getting close
    OMG i hate it. Its gonna take a wile but it will be done and i can finally finish my install.
  15. #15 Re: h bar removal
    Bowie, MD
    So heres where im stuck at for the moment reason why....i ran out of bits for my dremel. My question is can i install the blower like this untill i get new bits and gasket and finish it up? The h bar is half way grinded down.
  16. #16 Re: h bar removal
    Mexico
    hmm not sure, why not get more bits? Have you ported the LIM intake too? I think it's kind of pointless having a hbar less removed SC with the stock lim intake.
  17. #17 Re: h bar removal
    Bowie, MD
    Yes im doing this because im installing a zzp stage 2 intercooler.
    I cant get any bits because my impala is basically torn apart engine and bumper and i have no way to go buy any.
  18. #18 Re: h bar removal
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Yea sure you can install it again with the H-bar like that.............But I wouldn't bother installing that IC though, since you're just going to pull it off again to finish..........
    Oh, and I'd expect the turbulence that the half-grinded H-bar is going to cause will actually decrease your performance, but I'll let the experts chime in on that.
    For all your 3800 needs:
  19. #19 Re: h bar removal
    I'll be running a half grinded h-bar when I top swap (not my fault)
  20. #20 Re: h bar removal
    Bowie, MD
    lls might as well wait untill a ride comes home because the only gaskets i have are the garlocks zzp sent me i was gonna use for the intercooler
  1. egr removal
    By Tony in forum General Tech Discussion
    Last Post: 06-13-2011, 06:26 PM
  2. TB removal
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 12:19 PM
  3. S/C Removal Gaskets
    By TeeWX in forum General Tech Discussion
    Last Post: 03-23-2010, 01:08 PM
  4. Gas tank removal
    By daveg in forum General Tech Discussion
    Last Post: 09-09-2009, 05:17 PM
  5. Fog light removal...
    By Standby in forum General Tech Discussion
    Last Post: 07-31-2009, 01:53 PM
