Thread: Took apart the whole engine.. (Advice Wanted)
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 Took apart the whole engine.. (Advice Wanted)
    SE Level Member Hixc's Avatar
    Lawrence MA
    so i took apart the whole engine today because there was a loud knock noise coming from the inside of the engine. I had KR up around 14, and i am thinking i overboosted the engine. I had the P0121 code also. I was running a 2.8 Pulley, maybe i should of been going to the 3.0 or 3.1. i always use 93 octane. Here are my mods, and attached is a copy of my power tuners bin file. Turns out 6 Chipped Pistons. Pictures Below
    Triple Edge ported Gen III (inlet and outlet, setup for an I/C)Trannyman
    INTENSE Supercharger coupling
    INTENSE PCM
    INTENSE™ Stage 1X Blower Cam, duration @ .050": 210?/221?, lobe lifts: .321"/.329", valve lifts with 1.60:1 rocker arms: .514"/.526", lobe separation angle: 115?, intake centerline: 111?
    1.6 Roller Rockers 3rd gen
    LS6 105#
    INTENSE Oil Restricted Pushrods 5/16 X .083 X 7.50
    Comp Cam Lifters
    Rollermaster Timing Chain Set
    ZZP Valve Locks and Retainers
    42.5# Flow matched
    Walbro 255lph Fuel Pump
    MSP CAI
    Casper's Timing Commander
    ZZP Voltage booster
    MSD Ignition Wires
    Sprint Tech springs
    TOG headers back to a Thrush glasspack and Borla Pro XS mufflers with singe rolled tip
    Performance Tranny Rebuild 10k Miles Ago(Hardened parts, shift kit)
  2. #2 Re: Took apart the whole engine.. (Advice Wanted)
    Donating Users gtp239's Avatar
    ft myers fl
    pics?
    1998 gtp fwi, sd headers, overkill,3.4, poly mounts,p&psc
  3. #3 Re: Took apart the whole engine.. (Advice Wanted)
    Umm all them mods and a can tune? also I sure hope you had a wideband and a scanner becasue i dont see them in your list.............
  4. #4 Re: Took apart the whole engine.. (Advice Wanted)
    Lawrence MA
  5. #5 Re: Took apart the whole engine.. (Advice Wanted)
    Lawrence MA
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    yea i forgot to add that i have the Aeroforce Intercepter Gauges.
  6. #6 Re: Took apart the whole engine.. (Advice Wanted)
    ft myers fl
    junk yard bottom end and pulley up then get tuned, those pistons are tore up
  7. #7 Re: Took apart the whole engine.. (Advice Wanted)
    Lawrence MA
    Quote Originally Posted by gtp239 View Post
    yea, i was thinking of just doing a rebuild, the cylinder walls look like there in great shape and there were no scratches or damage (surprised). all the connecting rods were good, and bearings were all good. the valves in the head were all good as well. and when i found that my spark plugs were closing gap, i knew i had to take it apart.
    Do you think it would be worth buying these pistons?
    ZZ Performance
    id rather not have to get a whole new lower block if i don't have to.
  8. #8 Re: Took apart the whole engine.. (Advice Wanted)
    So Im not trying to hate if you have a scan guage how did you not see the KR? Esp with a 2.8 pulley? Like the other guy said get a junkyard bottom end pully up and get a real tune can tunes are good for a little bit but your mod list looks way beyond a can tune. And the results of the pistons prove it! Good luck hope its back on the road soon!
  9. #9 Re: Took apart the whole engine.. (Advice Wanted)
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    How many times are we going to cover this? Do not rebuild the bottom end. Buy a junkyard short-block. Get a low-mile L26 short-block and spend less money than on the pistons. These things are tanks from the factory and I've heard nothing good about rebuilds. They don't hold up. Go high compression and pulley up to a safe size.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  10. #10 Re: Took apart the whole engine.. (Advice Wanted)
    Lawrence MA
    Im sort of new to the whole GTP Performance Thing. I bought this car with all these mods installed, and i just learned how i could scan for KR with the gauge, and that is when i noticed it.
    I have uploaded the Bin file for my PCM. would be great if anyone could check this out to see if it was tuned properly. if there is a way of doing that.
    http://www.mediafire.com/?2ctwb6e1i022234
  11. #11 Re: Took apart the whole engine.. (Advice Wanted)
    Lawrence MA
    Ok So does having the L26 Shortblock with a L67 Head give higher compression then the stock GTP motor? if i do that, what pulley size should i start off with?
  12. #12 Re: Took apart the whole engine.. (Advice Wanted)
    your much father than any W body Ive owned and yeah an L26 has weaker rods some claim and yes the compression ratio would be more than the L67 all NA engines have higher compression ratios.
  13. #13 Re: Took apart the whole engine.. (Advice Wanted)
    Quote Originally Posted by Wrongwayislost77 View Post
    How many times are we going to cover this? Do not rebuild the bottom end. Buy a junkyard short-block. Get a low-mile L26 short-block and spend less money than on the pistons. These things are tanks from the factory and I've heard nothing good about rebuilds. They don't hold up. BECAUSE THEIR REBUILT BY PEOPLE THAT DONT DO IT RIGHT FIXED!!.
    Still believe the OMG dont rebuild a W body V6 is BS that comes along with believe what you want on the intenet forums. They can be rebuilt if people know what the hell their doing. How ever I would be on the side of that argument its prolly cheaper to buy a used short block!
  14. #14 Re: Took apart the whole engine.. (Advice Wanted)
    Quote Originally Posted by Hixc View Post
    l26 has 10.1 pistons
    the l67 has 8.1
    so if you go high compression you would need 3.4 or 3.6 pulley probably at the smallest to start out with. and scan for kr, then drop little by little so you dont blow it up again. inter cooler would be a good idea, sorry if i missed that you do in the list, not sure if you have one or not.
  15. #15 Re: Took apart the whole engine.. (Advice Wanted)
    Topeka, KS
    Ya way too small pulley for the mods you had. I'd get a new block and have someone tune it vs a canned tune. Generic PCM tunes can only do so much.
  16. #16 Re: Took apart the whole engine.. (Advice Wanted)
    L26 has 9.4:1. Just like the L36.
    L67 and L32 have 8.5:1 Compression.
    So...you were running a 2.8" pulley...ported blower...with an S1X...headers...bigger injectors and a different fuel pump...on a canned tune? I'm surprised it didn't pop the first time you went WOT.
    Anywho.
    Budget?
    Because that'll tell us what we can tell you.
  17. #17 Re: Took apart the whole engine.. (Advice Wanted)
    Topeka, KS
    Sounds like the previous owner was the re-re that put the 2.8 on there with those mods. Or at least i'm hoping in defense of the OP.
  18. #18 Re: Took apart the whole engine.. (Advice Wanted)
    Akron Ohio
    2.8 is crazy if your not intercooled or feeding corn too your car!
  19. #19 Re: Took apart the whole engine.. (Advice Wanted)
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    And if your SC is opened up for an ic(hbar removed) then open up that LIM as well to match it at least even if you don't have a IC yet it will just line up better and not create turbulence. BTW if your dead set on building a motor I have a set of those pistons brand new .030 over with a bored block with new cam bearings and freeze plugs(not sure what other if any machine work was done) and freshened rods for sale asking $400
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  20. #20 Re: Took apart the whole engine.. (Advice Wanted)
    short block is cheap.
    rebuild is not.
    Short block is used.
    rebuild is not.
    How much do you want to invest in this car?
  1. So I spun a rod bearing!!!! Advice wanted!!
    By ionroller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2010, 10:16 PM
  2. would like advice on best way to replace engine.
    By jj7ski in forum Introductions/Noob Questions
    Last Post: 07-18-2010, 10:47 PM
  3. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
