Thread: Intercooler fill plastic piece
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 Intercooler fill plastic piece
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    What stores can purchase the black 3 angled plastic piece in the pic below from? ZZP wants $12 for them but im sure i can get it for alot cheaper locally.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Intercooler fill plastic piece
    If all you need is a T, Lowes, Home Depot or Tractor Supply are my local places that would have it.
  3. #3 Re: Intercooler fill plastic piece
    GT Level Member RegalGS98s's Avatar
    NJ
    At Lowes check the aisle with the water pumps. At Home Depot should be at the end of the regular plumbing aisle. Not sure if they have them in black, but I know they have them in gray.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  4. #4 Re: Intercooler fill plastic piece
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    autozone has them.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Intercooler fill plastic piece
    SE Level Member BlackGS's Avatar
    Central Jersey
    I'm pretty sure that T is 3/4"x3/4"x1". It is not that common, and might be difficult to find in the Home Depot/Lowe's places. Try a plumbing supply store.
    I did a quick web search, and found it here cheap, but shipping is unknown:
    Plastic Mainline Reducing Tee
    Also, the vertical fill/vent tube doesn't really have to be 1". You could get a 3/4"x3/4"x3/4" T, and pick up a couple feet of 3/4" clear tubing instead.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  6. #6 Re: Intercooler fill plastic piece
    Bowie, MD
    Thanks for the help guys. Much appreciated.
  7. #7 Re: Intercooler fill plastic piece
    Bowie, MD
    My new stage 2 fmhe radiator from zzp came in today and i installed it. Sorry about the crappy pic.
    So turns out the radiator has a hole but didnt come with a plug to plug it up. Where can i get a plug to plug up the hole before i start filling it with coolant?
    Sometime like this red plug i guess...
  8. #8 Re: Intercooler fill plastic piece
    Why did you repost this in a new thread?
    *sigh*
  9. #9 Re: Intercooler fill plastic piece
    Bowie, MD
    lls i was told to put it in the same thread. Automatically thought a mod would delete the other. But i found a solution though. Now the only problem im having is sealing the bottom gasket (garlock) fml smh. Used a stock upper gasket and that works fine.
    And also this....
    Why is the 680 belt rubbing my coil pack??? Thought only 04+ gp's had this problem?? And my 680 belt is SUPER TIGHT with the intercooler sitting this high.
  10. #10 Re: Intercooler fill plastic piece
    Nope...you need to shim up the coil packs with washers.
  11. #11 Re: Intercooler fill plastic piece
    Bowie, MD
    Damn of all my readings, i never read about doing that. Thanks blue.
  12. #12 Re: Intercooler fill plastic piece
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Thats the S2 FMHE from ZZP? It looks different. Probobly because its a Impala right?
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  13. #13 Re: Intercooler fill plastic piece
    Bowie, MD
    Yes its a stage 2. Its actually different from the stage 2 that ive seen in other gtp's and the instructions that come with the stage 2 intercooler.
    So i managed to seal the bottom garlock gasket now and the car is smooth at idle. I have all the tubes ran and the pump mounted and everything. But when i grounded the negative wire and hooked the positive wire to my "Fuel Pump Relay Fuse", the pump starts working without me even starting the car. And the coolant doesn't even move through the tubings.
  14. #14 Re: Intercooler fill plastic piece
    Bowie, MD
    Here's a better pic.
  15. #15 Re: Intercooler fill plastic piece
    Atlanta, GA
    Hmm thats really weird. After doing some google searches, a couple other people received the same FMHE. Its strange because ZZP sells the same product as an aluminum "radiator". I know a FMHE is essentially a radiator but I dont know why zzp switched to this style. It may be because there S2 FMHE's are listed as out of stock. I like the old style better.
  16. #16 Re: Intercooler fill plastic piece
    Vancouver, WA
    I thought all the new FMHE's were direct bolt in below the bumper? I know mine from WBS is.
    Slowest 'Cooled Gen V ever
  17. #17 Re: Intercooler fill plastic piece
    Atlanta, GA
    I think the direct bolt in ones are for the GTPs only.
  18. #18 Re: Intercooler fill plastic piece
    Bowie, MD
    So solved the pump problem. My lines had a crink in it and now the coolant runs through the lines. I went for a drive with my new 3.2 pulley in but the car wasnt running any cooler. Temps went up to 185*.
  19. #19 Re: Intercooler fill plastic piece
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    Um... what? Where are you reading this 185* temp from and what are you reading?
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  20. #20 Re: Intercooler fill plastic piece
    Atlanta, GA
    Isnt an intercooler supposed to cool the air after the supercharger providing more horespower? I think your reading the normal engine coolant temperature gauge.
  1. need help finding location for black plastic piece!
    By mkedwards in forum General Tech Discussion
    Last Post: 04-13-2011, 10:43 AM
  2. Plastic piece/clip below key switch interior?
    By frtaylor9 in forum 04+ Specifics
    Last Post: 03-15-2011, 06:31 PM
  3. Replies: 28
    Last Post: 04-27-2010, 05:45 PM
  4. how do you take this black plastic piece out?
    By nemesis in forum General Tech Discussion
    Last Post: 04-25-2008, 06:21 PM
