Thread: Code P0440 - Evap Control
Results 1 to 5 of 5
  1. #1 Code P0440 - Evap Control
    SE Level Member lukashanson21's Avatar
    Jun 2011
    South Dakota
    I topped my 2000 gtp out at 124 mph and the service engine light came on, I ran the code and it said "P0440 EVAP CONTROL SYSTEM MALFUNCTION" but the car isn't driving any different. What could it be?
    - 2000 Pontiac Grand Prix GTP -
  2. #2 Re: Code P0440 - Evap Control
    Omaha, NE
    Turn your gascap until it clicks a couple times.
  3. #3 Re: Code P0440 - Evap Control
    Jun 2011
    South Dakota
    Thanks for the quick reply but that isnt it
  4. #4 Re: Code P0440 - Evap Control
    Omaha, NE
    Evaporative Emission Control System Malfunction
    What does that mean?This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
    Symptoms:
    You likely won't notice any drivability problems.
    Causes:
    A code P0440 could mean one or more of the following has happened:
    The gas cap is not installed or working properly
    The purge solenoid has failed
    The canister is plugged and not working properly
    Possible Solutions:
    With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
    Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
    Inspect the EVAP system for cuts/holes in tubes/hoses
    Inspect for damaged or disconnected hoses around the Evap purge solenoid
    Check and/or replace the sensor
    Check and/or replace the purge valve
    Have a professional use a smoke machine to detect leaks
    Source: OBD-II Trouble Code: P0440 Evaporative Emission Control System Malfunction
  5. #5 Re: Code P0440 - Evap Control
    SE Level Member Curt7's Avatar
    Jul 2011
    Ontario
    Had the same code last week. Replaced the purge solenoid, cleared my codes. Check codes today and nothing has returned and still no light. Part was only $20 from GM
    2003 Grand Prix GT
  1. EVAP code help
    By craig1980 in forum General Tech Discussion
    Last Post: 06-07-2011, 05:21 PM
  2. dtc code p0440
    By churchryan55 in forum Introductions/Noob Questions
    Last Post: 01-23-2011, 12:23 PM
  3. Delete EVAP code
    By Deathsports in forum PCM Tuning
    Last Post: 11-09-2010, 04:17 PM
  4. Check engine code P0440
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2009, 11:19 AM
  5. P0440 code
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:32 PM
