Thread: installing pace setter headers
Results 1 to 16 of 16
  1. #1 Re: installing pace setter headers
    SE Level Member Porach's Avatar
    United States
    ya it does sound bad. I'm going to put on new muffles maybe on Tuesday. i have the zzp computer on and the erased the P0420 trouble codes (which is the oxygen sensor codes). And i had zzp fix the leak in the y pipe with the headers. I'm not sure if that is the problem. Maybe i need a tune? because i have no back pressure and the car is supposed to run with everything. But i really don't think its a leak anymore because i made sure there was no air getting out anywhere on the down pipe and the y pipe and stuff. Or do you guys think that my o2 sensors have to go through a drive cycle and it might tune itself to run properly.
    Today when i was testing it i feel like its just not peeking when i go fuel throttle. So if this helps i want to see what everyone thinks.
  2. #2 Re: installing pace setter headers
    you dont need backpressure, its all a myth.
    99% of cars with a good working exhaust system make less than 1 psi of pressure.
  1. Installing Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 01-02-2011, 05:22 AM
  2. 1997 Pace Car
    By windowrattler in forum General Tech Discussion
    Last Post: 11-29-2010, 03:11 PM
  3. pace setter dp
    By badbrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 10:05 PM
  4. Installing Headers
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:25 PM
