Thread: Fuel pump question
Results 1 to 6 of 6
  1. #1 Fuel pump question
    SE Level Member black plague815's Avatar
    May 2011
    Illinois
    this might be a dumb question but, does the fuel pump slow down when you are low on fuel?
  2. #2 Re: Fuel pump question
    Charles City, IA
    no.
    SMGPFC Two Nipple General
  3. #3 Re: Fuel pump question
    No, however in a Supercharged of say 97-03 (I'm unsure on 04+) there is a resistor that lowers the pump speed when you are below a certain throttle percentage.
  4. #4 Re: Fuel pump question
    bill--is that resistor bulit into the fuel pump(the module) or is it an external componet?
    SMGPFC Member #10
  5. #5 Re: Fuel pump question
    External. Originally located behind the washer pump under the bumper
  6. #6 Re: Fuel pump question
    just on the signal wire to the pump?...
    the reason i ask is because a friend of mine has a 98 gtp and they took it to the shop for maintence and they were told that the car is running rich at idle and they were told that is was the fuel pump resistor and wanted 400 to fix it?..woundering if its the same thing?
    SMGPFC Member #10
  1. Fuel pump question.
    By ExLimey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2011, 06:08 PM
  2. Fuel pump question
    By zildjian102 in forum General Tech Discussion
    Last Post: 12-11-2010, 12:35 AM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. Fuel pump question
    By JoelW98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2009, 09:28 PM
  5. Fuel Pump Resistor Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2009, 04:49 AM
