Thread: New Build almost done! Cam idle video
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #1 Re: New Build almost done! Cam idle video
    Quote Originally Posted by bballa0740 View Post
    your right im lieing.....?
    im just saying, its pretty hard to produce that much boost on an m90. the NIC has a ton of overlap so that it would bleed off boost. it makes sense that youre overdriving it on a 2.55 to keep boost levels high, but even 20 seems high.
    how's your tune looking? what kinda timing are you running?
  2. #2 Re: New Build almost done! Cam idle video
    Feb 2009
    flintnasty MI
    Seems normal to me, those rockers float like a SOB.
    The fact that I dont know anyone making good power (330whp+) on a m90 and makes more than 13psi of boost confirms this.
    its just been to hott to go beat on it
    More heat = less air = less strain....
  3. #3 Re: New Build almost done! Cam idle video
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    Wow, that's a fast spinning Gen V...
    In for video of that whine!
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  4. #4 Re: New Build almost done! Cam idle video
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    What he said!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  5. #5 Re: New Build almost done! Cam idle video
    utah
    why do people say things arent possible....when i bought my car in 04 everyone said iot wasent possible to run anything smaller then a 3.5 without an ic...and now look. just about anythings possible (outside of the obvious) so stop tellin people things cant happen. on another note, that thing sounds amazing
  6. #6 Re: New Build almost done! Cam idle video
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    NIC cam sounds like pure sex... I luz it.
  7. #7 Re: New Build almost done! Cam idle video
    woooooooooooooooooooooooooooooooo
    smexy.
  8. #8 Re: New Build almost done! Cam idle video
    GT Level Member bballa0740's Avatar
    Apr 2009
    br
    ill get some videos of open cut out and blower wine later if it cools of its like 94 out right now
    E85, Gen V, TOG Headers, 2.55 w/ SFI balancer, 3PE, Tranny, NIC Cam, 1.7 Yella Terra Rockers, LS6 springs, ...goood day sirrr ryan carter tuning
  9. #9 Re: New Build almost done! Cam idle video
    Dec 2008
    Alabama
    What rpm dose the engine idle at?
  10. #10 Re: New Build almost done! Cam idle video
    Apr 2009
    br
  11. #11 Re: New Build almost done! Cam idle video
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    ^^^Giggity Gooooooooo
  12. #12 Re: New Build almost done! Cam idle video
    Topeka, KS
    Video sounded good until you got on it. She scoots pretty well though.
  13. #13 Re: New Build almost done! Cam idle video
    GT Level Member tylerbinski's Avatar
    Canada
    im impressed with the idle and the car looks really nice..
    but i have to say..when you got on it tho.. it sounds terrible..
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  14. #14 Re: New Build almost done! Cam idle video
    Quote Originally Posted by tylerbinski View Post
    that vid was of open pipe, so of course its sounds like ass, hes got a cut out on the exhaust.
    thats for scaring the crap out of old lady's on the highway lol
  15. #15 Re: New Build almost done! Cam idle video
    Apr 2009
    br
    ^^^what he said and idle is at 750 im working on getting some vids its just been to hott to go beat on it
  16. #16 Re: New Build almost done! Cam idle video
    Windsor (ON) Canada
    ooohhhhh your neighbours are gonna looooove you !!
  1. 2007 Grand Prix XP Build 9/20/2012 Dyno Run UPDATE!!!
    By MidnightBlue in forum Members Rides
    Last Post: 09-21-2012, 12:29 AM
  2. Help.. Strange Idle (video) after 1.9's/LIM gasket -
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:33 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. and...the build begins *UPDATE*IDLE VIDEO!!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 06-07-2010, 03:19 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
