Thread: Need Help Please
Results 1 to 6 of 6
  1. #1 Need Help Please
    Nov 2010
    Marine City MI
    My car's been running bad, so I pulled the codes, P0102 came up, I bought a new 85mm MAF from zzp, plugged it in and the car ran a tad better. It felt like it normally does when I would roll into the throttle but cruising at a slow speed leaves something to be desired, the car shutters and lurches some. My Aeroforce gauge does not pull any frequency or MAF/LB MIN readings it just stays at zero.
    Things I've Done,
    I've unplugged the new MAF and the car ran worse so I feel like it's doing something, the old MAF the car would not run plugged in, unplugged it ran.
    I pulled the pcm, I wanted to make sure it was seated correctly.
    Cleaned the TB and SC inlet.
    Changed the 02 extension it was cooked by my headers. Also wrapped it with a piece of an old starter sheild I had.
    Traced the wires, checked for vac leaks.
    What should I check next? I don't want to keep throwing parts at it. Could the new MAF be bad as well?
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  2. #2 Re: Need Help Please
    Omaha, NE
    Have you tuned your PCM for the larger MAF?
  3. #3 Re: Need Help Please
    Nov 2010
    Marine City MI
    Yes the car was tuned before I took ownership.
  4. #4 Re: Need Help Please
    Omaha, NE
    But has not been tuned for the larger maf... That could be the issue.
  5. #5 Re: Need Help Please
    Charles City, IA
    If its not reading maf hz check the ign 1 fuse.
    SMGPFC Two Nipple General
  6. #6 Re: Need Help Please
    Nov 2010
    Marine City MI
    Quote Originally Posted by TheOtherNick View Post
    I just checked fuse 21 it was bad, all is right once again.
