my dummy light popped on. Im running code 0172; rich bank 1. I've checked and double check and I don't have vacuum leaks. I've checked my wires and they are good, maf is relatively new, as is tps. Plan on checking plugs tomoro. May have an small exhaust leak at the Y-collector pipe. What else do I need to check to fix this problem? I'm getting rocker arms and springs installed tomoro and I don't want any problems.
