Thread: List possible oil leaks? :(
Results 1 to 13 of 13
  1. #1 List possible oil leaks? :(
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Alright. I replaced the front gasket ( the crank seal was fine), oil pan gasket, v\c gaskets,oil filter housing gasket and its still pouring out oil. The only other thing I can think of is the oil pressure sensor. Do you guys have any ideas?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: List possible oil leaks? :(
    either the oil level sensor or the oil pressure sender could be leaking. teflon tape on the threads helps.
  3. #3 Re: List possible oil leaks? :(
    Orland Park, IL
    Where is the oil pressure sender in referance to the sensor?
  4. #4 Re: List possible oil leaks? :(
    on the oil filter neck going to the block. you'll see it.
  5. #5 Re: List possible oil leaks? :(
    Orland Park, IL
    I thought that was the sensor lol. Where's the sensor than?
  6. #6 Re: List possible oil leaks? :(
    St. Louis
    The oil pressure sensor is in the oil filter adapter housing. The oil level sensor is the big sensor that is screwed into the front edge of the oil pan.
    Did you replace the valve cover grommets when you did the V/C gaskets? Could be leaking from there still.
    Where exactly is it "pouring" oil from?
  7. #7 Re: List possible oil leaks? :(
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Did you RTV the front cover gasket and the oil pan gasket, at where they meet?
  8. #8 Re: List possible oil leaks? :(
    What is the origin area of the oil?
    If you don't know. Clean the snot outta the engine and run just enough to get an idea.
    Get under and look up. You'll see oil seeping down the heads if it's the valve covers. Speaking of VC's did you use new grommets?. Look at the oil filter area, any leaks should be obvious. Now.. leak at the front cover is possible, as is the front main seal. Then there's the tougher ones. If the back end of the oil pan is wet (trans end) that can commonly be the rear main cover. The bolts are on w/o threadlock and at such a retardedly low torque that they do back out and cause a leak. Another is teh oil pan. Sometimes misdiagnosed though.
  9. #9 Re: List possible oil leaks? :(
    Orland Park, IL
    It actually was the oil pressure sensor. Thanks guys!
  10. #10 Re: List possible oil leaks? :(
    St. Louis
    Good deal! And thanks for posting the solution. May help someone else.
  11. #11 Re: List possible oil leaks? :(
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I just found out today that my oil pressure sensor is also leaking (left a nice oil puddle outside my house). I replaced it with a local brand back in January, now it's busted again.
    What brands do you recommend? I was planning on either getting the Autozone brand or the one at the dealer.
  12. #12 Re: List possible oil leaks? :(
    ive had 3 of them blow on me, i sealed mine up with a brass plug for now, down the road im going to just pop in a oil pressure gauge, and call it a day.
  13. #13 Re: List possible oil leaks? :(
    St. Louis
    Auto Meter - Oil Pressure Gauge
    Part Number: 3327
    Line: AUM
    • UPC: 46074033278
    • 2-1/16 Inch
    • 0 - 100 PSI
    • Short Sweep Electric
    • Includes 1/8 Inch NPT Sender, 1/4 Inch NPT Adapter/Fitting
    $77.99 Each
    OReilly's
    Here's you're solution. Comes w/ the sender. Just get yourself a 2 or 3 hole gauge pod for the pillar and wire it up. No chance of having oil inside the car either. I run this one in my GT and it works just fine.
  1. Valve Cover Gasket Leaks & Possible Intake Leaks
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 07:48 AM
  2. sUnRoOf LEAKS! HELP!
    By kplouis3167 in forum Introductions/Noob Questions
    Last Post: 09-03-2010, 03:50 PM
  3. LIM Vacuum leaks?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 05-25-2010, 01:44 PM
  4. leaks...
    Last Post: 04-21-2009, 10:20 PM
  5. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
