Thread: Upgrade injectors?
Results 1 to 8 of 8
  1. #1 Upgrade injectors?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I just made the first scan with the new setup. looks like the max IPW I've got so far is 16.8. I still have to lean the AFR for the SSIC. I'm guessing that I can still run a 3.0 pulley with the stock injectors. What do you guys think?
    I do plan to get bigger ones, but not just now.
  2. #2 Re: Upgrade injectors?
    IIRC 18.5 is about as high as you'd want to go.
    Some say 21, but thats kinda high.
  3. #3 Re: Upgrade injectors?
    is that with your 3.0 on? sometimes IC guys can get away without upgrading right away because they can run leaner IIRC....
  4. #4 Re: Upgrade injectors?
    Pretty sure once your hitting 20's you need bigger injectors. Those don't look like they are maxed out to me.
    But...any smaller of a pulley...or if you up the fueling in your tune...I bet you'd run them dry.
  5. #5 Re: Upgrade injectors?
    IDC of 85%+ is time for an upgrade.
    Fuel Injector Pulsewidth Calculator
    Inputs:
    231.3, 850 , 6000, 10, 6, .5, 21, 300, 1, 42.5, 1, 4.
    Output:
    Injector Size @ 80% recommended duty cycle (lb/hr): 31.25 Lb/Hr
    Max Hp with recommended injectors @ 85% duty cycle: 318.750 Peak Hp
    Max Pulse Width Permitted @85% duty at peak rpm: (Ms): 17.000 Ms Peak
    Max HP with Your Installed Injectors @ 85% duty: 433.500 Max Hp
    Idle Millisecond Pulsewidth: Installed Injectors 1.700 Ms Idle
    Projected cc's per minute: Installed Injectors, per injector at idle:3.503 cc's / Inj.
  6. #6 Re: Upgrade injectors?
    Mexico
    Quote Originally Posted by gtpsleeper View Post
    That was on a 3.1, I still need to buy a 3.0 assuming that I also max out the spark advance on this one.
    My guess is that I can get away with the stock injectors because of the altitude. My rationale is that with less oxygen in the air, less fuel used. I also think that if I bring it down to sea level, the injectors will be maxed out.
    Thanks for the info guys.
  7. #7 Re: Upgrade injectors?
    Reason being why people in Colorado and higher altitude places can get away with smaller pulleys...
  8. #8 Re: Upgrade injectors?
    Thats based on 6000 RPM.
    Its lower the faster you want to spin.
    Might get different numbers from different calculators, but the same idea applies.
  1. possible upgrade.......
    By BBluelandyacht in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2011, 09:32 PM
  2. upgrade
    By conradgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2010, 03:10 AM
  3. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  4. L26 upgrade
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 12:33 PM
  5. Next Upgrade?
    By 04gpking85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2008, 07:39 PM
