Thread: 97 GTP has hardly any power.
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 41 to 60 of 186
  1. #41 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    Plugs are roughly 3 months old .
    Wires are new from ngk.
    Running regular octain 87
    I dont put nothing in the gas,
    Stock pully
    No pcm programmin done
    Post are clean on the coil packs and trottle body screen is left there stock and is in place..
    .... Soo thats why i have power before it warms up.. Should i change my thermostate?you think i need plugs. Which ones should i get? Help me out plz
  2. #42 Re: 97 GTP has hardly any power.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You need to be running premium fuel. This very well could be your problem. Put in premium and repost your results.
  3. #43 Re: 97 GTP has hardly any power.
    Quote Originally Posted by guimond47 View Post
    Stock pully
    Found the knock problem. Very gently and nicely w/o going past 1/3 throttle burn off the rest of your tank and fill up with 93 octane from now until you sell the car. leave the plugs and wires alone. they are likely fine.
    The reason octane is so important in these motors is because of the added boost pressure. What happens is the cylinders get hot very quickly and that can make lower octane fuel burn before the spark ignites it. This causes predetonation. The more boost, the more likely the air/fuel charge will ignite before the correct time. It's also very easy to chip a piston when beating it this way. The octane keeps the fuel from igniting as easily.
  4. #44 Re: 97 GTP has hardly any power.
    MO
    The fact that you are running 87 octane only strengthens bill's fact that you are probably causing high KR
    <brandonl2000> LMAO D!!
  5. #45 Re: 97 GTP has hardly any power.
    MO
  6. #46 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    Would octane booster do the same as running higher octAne? If soo what should i buy. 93 octane is expensive here in canada ontario..
  7. #47 Re: 97 GTP has hardly any power.
    Octane booster usually raises octane one point. Meaning if you start wtih 87.0 octane, you end up with 87.1 octane. that's a lot of booster.
    Yes it is expensive for you. I have friends up there. It's what your car was born to guzzle. Sorry.
  8. #48 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    Soo octane can actually make that much of a difference of power in the 3800's?
  9. #49 Re: 97 GTP has hardly any power.
    Kansas
    Yes, the power loss you have is due to detonation and your computer is reducing the timing to save your motor. Your lucky if you didn't already chip a piston or trash your engine.
  10. #50 Re: 97 GTP has hardly any power.
    Kansas
    If you have to... drain the gas... sell it to someone.... and get 93. You have a very high potential of ruining your engine running 87 octane.
  11. #51 Re: 97 GTP has hardly any power.
    I knew nothing about what octane actually did before I had a supercharged car either. Once you find out it's like ...Oh.. crap.
    In your case it'll be "oh crap .....eh!"
  12. #52 Re: 97 GTP has hardly any power.
    Ohio
    can some one PLEASE just steal his car (and his keyboard for that matter)?!?!oneone!!
  13. #53 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    Holly Shiattt ehh. soo thats why i have no power on take off? ill run 93 octane in it and see if it changes anything.... if it dosent then that cant be the issue here... ill post it up wen i filler up. i only have 1/4 tank left ... ill run it till below empty and fill it.
  14. #54 Re: 97 GTP has hardly any power.
    Ohio
    trust us .....you WILL notice the difference
  15. #55 Re: 97 GTP has hardly any power.
    SE Level Member Code's Avatar
    Jun 2011
    Wells, MN
    is it running hot? those superchargers get real warm under that plastic cover on top of the motor. just take it off and try running it like that.
    1 Pioneer 760Watt Amp, 1 Lanzer 12" Sub, 1 Bazooka 12" Sub
  16. #56 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    yea it runs really hot , i noticed that as well. you open the hood and its like wow. but the temp gauge is fine. and now i cant wait to try it:P
  17. #57 Re: 97 GTP has hardly any power.
    Keep in mind.. the pcm will be using the low octane timing tables it's gonna take maybe 50 miles or so until you start seeing the timing come back. Without the knock though..you will likely feel power within the first 20 miles.
    If you don't, then it's very probable that you chipped a piston and need a motor. Shattt doesn't quite desribe the feeling you'll have if you hurt the motor by using crap gas. Hopefully ...the pcm saved you.
  18. #58 Re: Champion Spark Plugs?!?!:S
    Any mods?
    Stock car or a few bolt ons but still a stock pulley I'd say AL605 or 606's gapped @ .050".
    3.4" setup...AL104's.
  19. #59 Re: 97 GTP has hardly any power.
    Apr 2011
    sudbury
    only has a home made intake fender kit cold air and has stock pulley
  20. #60 How To reduce as much KR possible.
    Apr 2011
    sudbury
    What mods can i do to eliminate as much KR possible on my stock GTP with the 3.8 pulley.
    ill be wanting to put a 3.4 -3.2 inch pulley on later soo i wanna get prepared and reduce KR first. i know the u bend delete is one. but what else.?? i already have a cold air system too . anyone can help a newbie out thanks
    its a 97 gtp
  1. Fan's no power
    By trigun87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2012, 08:49 PM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  4. No more power
    By 03gtdude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 01:07 PM
  5. Need more N.A power
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-21-2008, 01:32 AM
