A turbo guy dynoed the stock l67 block with a blockoff plate on after removing the snout and rotors for the supercharger and it dynoed at 147whp I believe.
I have the same knock/gutless problem, and similar mods. I have DTC P0134 (front 02 no activity) which is hopefully the cause. Thats probably a result of extending the 02 harness.
Will be fixing this when my life allows me.
I feel its still safe to drive without boost, with the SC belt on.
OOOOOOOOOOOOOOOOOOO...can I borrow your motor and check it with a ?stethoscope??
I wanna look for chipped pistons![]()
Whose? Mine? Sure, if you send me the money to ship it to you I'll be more than happy to send it your way....
It doesn't have any chipped pistons... I pulled the belt off it to prevent that. It runs like a champ without the belt, and pulls 20 inches of vacuum. Idles perfectly. And if by some small chance it did... who cares, still runs good for my DD.
dont run without it unless its a emergency and dont give it too much gas (activate boost)
