Thread: Service "vehicle" soon, trac off and ABS light all on
Results 1 to 19 of 19
  1. #1 Service "vehicle" soon, trac off and ABS light all on
    SE Level Member 98RegalGS's Avatar
    Victorville, CA
    My 98 Regal GS has just popped some lights on. The Service "Vehicle" Soon NOT the Service Engine Soon, the ABS and Trac Off lights are all on. What the heck is going on? Thanks for the help.
    98 Regal Gs L67 SC. 3.4 Pulley, SLP CAI, 3" downpipe with no u-bend, resonator delete, TB spacer, TB heat shield, 17" Caddy CTS wheels.
  2. #2 Re: Service "vehicle" soon, trac off and ABS light all on
    I thought SVS and SES were the same thing?
    ABS and TRAC lights are probably meaning you got a bad wheel bearing/hub assembly...or the sensor just went bad in one of them...but you have to buy the entire assembly.
  3. #3 Re: Service "vehicle" soon, trac off and ABS light all on
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I have found some cars do all that when the alt is low on voltage. Not quite enough to trigger the battery/alt light. Can't hurt to check the charging system.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  4. #4 Re: Service "vehicle" soon, trac off and ABS light all on
    Nov 2010
    Atlanta Ga
    service vehicle soon usually comes on for body control/abs faults or low level codes
    Service engine soon is usually on for engine/transmission codes
  5. #5 Re: Service "vehicle" soon, trac off and ABS light all on
    Victorville, CA
    Quote Originally Posted by kevins View Post
    Exactly Kevins. Will a scanner read the ABS codes just like the DTC's? I have a scanner to scan engine codes. Wifey is at work in the car so I can't try it right now. Do you need a special scanner to scan ABS codes? Thanks
  6. #6 Re: Service "vehicle" soon, trac off and ABS light all on
    Nov 2010
    Atlanta Ga
    Hard to say, some do some dont.
    Id like to see a pic of the regal with CTS wheels. Cant decide which wheels i want to go with.Im leaning torwards lucerne wheels for now.
  7. #7 Re: Service "vehicle" soon, trac off and ABS light all on
    Nov 2010
    Atlanta Ga
    Quote Originally Posted by torq455 View Post
    Funny how many unrelated things can cause wheel speed codes. I chased wheel speed codes for a month on my vette only to find out it was the stainless steel braided brake hoses!
  8. #8 Re: Service "vehicle" soon, trac off and ABS light all on
    Dec 2008
    Alabama
    How the hell does that work?!
  9. #9 Re: Service "vehicle" soon, trac off and ABS light all on
    Nov 2010
    Atlanta Ga
    Im not smart enough to explain it! Something about the lines generating static electricity.. I had alot of help on that one. I thought it was BS untill i swtched to a diff brand and sure enough all wheel speed codes were gone.
  10. #10 Re: Service "vehicle" soon, trac off and ABS light all on
    Victorville, CA
    Click on my Avatar pic and check out my Albums to see pics of the caddy wheels on my car. Thanks for all of the help.
  11. #11 Re: Service "vehicle" soon, trac off and ABS light all on
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    This ^ i had the same problem
    and came to find out both of my hubs went out at the same time.
    i hate our roads!
  12. #12 Re: Service "vehicle" soon, trac off and ABS light all on
    Dec 2008
    Alabama
    not the roads. It's a poor quality hub assembly. I had to replace both of mine under 75K miles.
  13. #13 Re: Service "vehicle" soon, trac off and ABS light all on
    OKC, Oklahoma
    Mine lasted 132k miles
  14. #14 Re: Service "vehicle" soon, trac off and ABS light all on
    Donating Users GrandpaAl's Avatar
    Salt Lake Utah
    I recently replaced the struts on my car, didn't get the right rear ABS sensor plugged in all the way and it threw the same codes once it wiggled out. Have you done any work to your car lately?
  15. #15 Re: Service "vehicle" soon, trac off and ABS light all on
    Victorville, CA
    Quote Originally Posted by GrandpaAl View Post
    I just did the Lower Intake Manifold gaskets but nothing near the hubs. Listen to this weird thing my car did today. When I first start the car all of the lights are OFF. As I drive it the "Low Trac" flickers for a while. While it's flickering the car kinda pulls to the right side as if the right front brake is being applied. After about 5 times the 3 lights (ABS, Service Vehicle Soon, Trac Off) will come on the dash and the pulling stops and the car acts normal from there on. Any ideas? Thanks
  16. #16 Re: Service "vehicle" soon, trac off and ABS light all on
    Nov 2010
    Atlanta Ga
    Could guess all day long, best bet it see what is triggering the code.
  17. #17 Re: Service "vehicle" soon, trac off and ABS light all on
    Salt Lake Utah
    That's pretty much the sequence my car went through also. I noticed too the power steering seems to not be working as strong as normal. This could be best solved by starting with checking the codes and running them down one by one. If you don't have a code reader, you should get one, go by a parts store and have them check it. Several of them around me do this for free, hoping to sell you something as a result.
  18. #18 Re: Service "vehicle" soon, trac off and ABS light all on
    Victorville, CA
    Fixed the problem finally!!!! I found the wire harness/ plug that goes to the right side front wheel just hanging. It had come loose from the little metal clip that holds it to the lower A-arm. I guess it was just jumping around down there and fooling the ABS into thinking that tire was spinning. All I did was reattach the harness to the a-arm by pushing the metal clip back on. Easy fix that was causing major headaches.
  19. #19 Re: Service "vehicle" soon, trac off and ABS light all on
    cool, you found a free repair, lol love them.
    i have a 98 regal too, and when i bought mine every light was lit up, my dash looked like a x-mass tree lol very annoying to have lights on all over the dash. im down to a air bag light that still needs to be fixed.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  3. "half" light tinting expiriment. looks cool. check it out.
    By colindunn in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  4. "CHECK GAGES" And Battery Light?
    By K7Gixxer750 in forum General Tech Discussion
    Last Post: 11-22-2009, 04:16 AM
  5. Service Vehicle Soon Light, No Codes
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:03 AM
