Thread: Removing steering wheel
Results 1 to 2 of 2
  1. #1 Removing steering wheel
    Apr 2011
    Gainesville, FL
    I have to remove a steering wheel from a 97 grand prix. It doesn't appear that the kit I borrowed from Advance Auto will do the trick because it doesn't look like there are places to insert the kit's bolts on the steering wheel. Is this correct? Can I make this kit work?
  2. #2 Re: Removing steering wheel
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    You have to have a kit that has the "legs" in it. There are no bolt holes to screw into. I was able to find a kit at O'Reilly's that had them.
    Performance Tool W80651 - Steering Wheel Puller Set | O'Reilly Auto Parts
  1. need help removing rear wheel bearing hub assembly
    By tiedye in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:15 AM
  2. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
  3. Steering Wheel
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-27-2010, 11:41 PM
  4. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
