Thread: Interference on a non-interferencemotor?
Results 1 to 20 of 32
  1. #1 Interference on a non-interferencemotor?
    SE Level Member GP_Kid18's Avatar
    May 2008
    Palatine,Illinois
    Thats what my tuner told me, he said my timing chain had jumped and that my pistons hit my valves, now i am in need of a new motor, a few of my friends think this guy is trying to pull one over on me, so they said i should post up here to see if anyone else has had this problem, or may know something about interference in a non-interference motor.
  2. #2 Re: Interference on a non-interferencemotor?
    If you chipped a piston and the chunk of piston is big enough you can mess up valves.
  3. #3 Re: Interference on a non-interferencemotor?
    not a chance that your timing chain jumped unless your tensioner was GONE.
  4. #4 Re: Interference on a non-interferencemotor?
    St. Louis
    What makes you think you need a new motor? Does it still run? Make any wierd noises? We need more info before we can help you.
    A year/model/and any mods you have installed will help as well.
  5. #5 Re: Interference on a non-interferencemotor?
    I live here. TLSheff's Avatar
    Quote Originally Posted by FordMan77 View Post
    About GP_Kid18
    Name - Paul
    Location - Palatine,Illinois
    Ride - 2004 GP GTP
    Engine type and displacement - 3800 series III 3.8
    Induction - S/C
    Major modifications - SLP Catback and Custom Cold Air Intake,MSD coil packs,TOG Headers, 3.4
    Tranny type - Automatic
    Tires - Street Radials
    Race weight - 4800
    Horsepower - 260
    Public Profiles sometimes have useful info.... Possibly chipped a piston given that your rocking a 3.4 on the that GenV with only intake and exhaust work.
  6. #6 Re: Interference on a non-interferencemotor?
    St. Louis
    About GP_Kid18
    Name - Paul
    Ride - 2004 GP GTP
    Induction - S/C
    Race weight - 4800
    Horsepower - 260
    Duh. Never even thought to look there. Usually can tell from the post. I'll try and remember to check that
  7. #7 Re: Interference on a non-interferencemotor?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    gm 3800's are interfearance engines
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Interference on a non-interferencemotor?
    If your pistons hit the valves...then ya youz gonna have issues.
    Ummm, as well as the GenV on the 3.4" with just headers...shoulda been running a 3.6" at the smallest.
    Probably too much knock bruh.
  9. #9 Re: Interference on a non-interferencemotor?
    Banned
    CT
    Why should he not be smaller than a 3.6 if he has headers and a GenV? Would this be an acceptable pulley size on a GenIII?
  10. #10 Re: Interference on a non-interferencemotor?
    Portland Oregon
    Quote Originally Posted by SnowFlake View Post
    Gen V's are more efficient at moving air so rule of thumb is the pulley size on a gen V should equal about .2 more than a gen 3. I had KR with my 04 when I tried a 3.4 on basically headers and a tune. Mostly went away when I pullied up to a 3.6
  11. #11 Re: Interference on a non-interferencemotor?
    Banned
    CT
    Quote Originally Posted by OH4CompG View Post
    So help me to understand this... the GenV is more "efficient" (how so?) and this means you NEED to pulley up about .2 VS what you would run on a GenIII?
    I'm just trying to figure out why.
  12. #12 Re: Interference on a non-interferencemotor?
    Hagerstown,Md
    Because of what happened. Esp if he was on a hot plug
  13. #13 Re: Interference on a non-interferencemotor?
    Waukesha, WI
    gen 3 is like a fat kid breathing through a straw
    gen v is a fat kid breathing through a sewer pipe
    effiency
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  14. #14 Re: Interference on a non-interferencemotor?
    Banned
    CT
    Quote Originally Posted by redlinepontiac View Post
    effiency
    Okay so what you're saying is that the GenV is easier to spin at boost? Or that the air temps post blower are colder?
  15. #15 Re: Interference on a non-interferencemotor?
    because of the outlet shape and the more efficient design of the case, the heat created at a certain level of boost is less than that of the gen3.
  16. #16 Re: Interference on a non-interferencemotor?
    Banned
    CT
    Good info here. But I'm still confused. Why do our cars knock?
  17. #17 Re: Interference on a non-interferencemotor?
    knock = pinging = pre-detonation. do yourself a favor and google it.
    our 'KR' is the PCM reacting to pre-detonation. so if you see KR, it's already too late. however, the car is very good at what it does which is why we are able to tune based on KR levels.
  18. #18 Re: Interference on a non-interferencemotor?
    Banned
    CT
    Okay so what I've gathered is that our cars knock because of the excessive heat generated by our blowers... didn't even have to google that!
    So I'm just trying to organize all of the points made here into a coherent overall "big picture"
    The GenV is more efficient in such a way that it creates less heat than the GenIII pulley vs pulley. But when switching to the GenV from the GenIII typically you need to go up .2'' in pulley size so you don't knock due to the better efficiency of the GenV blower. So since the OP has a 3.4 pulley with only headers and other small supporting mods you guys think he chipped a piston and shouldn't be running lower than a 3.6 pulley, but on a GenIII which blows air at a hotter temp, a smaller, more heat creating pulley would have been okay... since a lot of people run 3.4s with headers.
    Am I on the right track?
  19. #19 Re: Interference on a non-interferencemotor?
    Have you not seen our factory exhaust systems?
    And...
    The GenV has better designe rotors/different coating.
    The GenV doesn't have the "ramp up" effect that the GenIII does that you can somewhat cure from porting/polishing and filling the dip in the inlet.
    Also...to clear this up...I typed this up a long time ago:
    oooooooooooooooooooooooohhh...I've typed this a few times...here goes.
    The reason people upgrade from the GenIII to the GenV is a couple reasons...one being efficiency...you can get away with smaller pulleys on a GenIII but your yanking more power off of the motor to do so...where as the GenV...you can make the same power with a larger pulley and take less power off the motor to do so. The other reason being the rotors never flake apart from what I've seen...GM skimped on the GenIII's and it shows...the coating on the GenV's rotors are tits. The inlet to the GenV also doesn't "ramp" up like the GenIII's do...so you don't have to worry about the air having to run up to get to the rotors...guess you could call it an obstruction. Typical rule of thumb...I don't really say .2"...because some people will have different results. I will say that most 3.4"/3.25" setup GenIII cars are the same on GenV cars with a 3.6"/3.4" setup. You've just gotta mod more to drop pulleys on the GenV's. Also...according to Eaton...anything lower than a 2.8" on a GenV makes it spin WAY too much...causing a big break in inefficiency...only thing I would do...if you were GenIII and just kept running down in pulley sizes is this...when you get to a 2.55" on a GenIII, go to a 2.8" GenV...and be happy.
  20. #20 Re: Interference on a non-interferencemotor?
    more boost per pulley goes along with the gen3 vs gen5 debate too. efficiency not only means cooler outlet temps, but more boost.
  1. interference
    By pontiac88 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:10 PM
