bluegtp91
Thanks for that useful post...I'll look into it...Right after I install a few XP's and S1X's with L76 and LS6 springs.
.............................maybe you should check your springs...see how they're doing. Hopefully you didn't get stuck with one of the bad Mexico batches like thousands of others did.
OP: Like stated, I ran LS6 Springs for over 40k...got rid of them and my XP for 130's and the Thrasher for my build. I daily'd the car for about 2 years that way then parked it and shoved it aside. On any aftermarket cam using the stock chain/dampner...I would however tell you to yank off the front cover and check the dampner every 50K or so...because depending on where the idle is set at, it could chew it up pretty quick. I had my idle set at 750. Dampner was almost gone after 40,xxx. Or you could bypass all this petty back and forth bullsh1t and get Manley 130's. Then you could really rev it and utilize every bit of the powerband of the XP and not have to worry about which valve springs to buy.
